SOURCE: my freezer leaks about a pint or so of water every
At the bottom of your freezer it maybe behind the back cover there is a hole about a 1/2" in diameter that the water drains down to the drain pan underneath, This is clogged up. You might have ice in it also so first try putting some warm water down this drain hole to melt the ice and you might have to run a piece of wire down it to free up the obstruction.
This ball is referred to as a widget. Guinness contains less CO2 than other
beers. The purpose of the widget is to
release the CO2 from the beer in the can to produce head. The widget is added to the can prior to
sealing. View the site below for more
details.
