Dehumidifiers Logo
David Brooks Posted on Feb 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have run our machine twice for an hour+...no condensation happening.
We hadn't used the machine for a couple of years so have forgotten any settings we've used in the past. There's definitely humidity where we're running it (in our basement where we are dealing with some water leakage). We've run a couple of times, 1 hour & more each, using auto once, & other settings as well without luck. Appreciate any suggestions! Thanks...David
Stephen Miller
Level 3:
  • Master 1,645 Answers
  • Posted on Feb 23, 2019
Stephen Miller
Master
Level 3:
Answers
1645
Questions
0
Helped
866206
Points
9471
5 Related Answers
Anonymous
  • 135 Answers
  • Posted on Aug 04, 2007
SOURCE: Does not collect water
The only thing you really need to check is that collector coil that the the water is supposed to condense upon, much like the "sweat" on a glass of ice water. If that collector coil is not nice and cold, then your machine needs freon or has some other serious problem.
Anonymous
  • Posted on Jun 23, 2008
SOURCE: User Manual has no guidelines.
When you first turn on the unit it is set to 40% humidity which is the lowest the unit will accept. You can only move the up arrow from that point. The 63 you are seeing is the actual humidity. If you want 50% youo need to press up arrow till 50 is displayed. The manual for this unit is terrible. Just leave it as it is and it will attempt to bring it down to 40%. 30 to 50 is the recommended humidity range.
Anonymous
  • 121 Answers
  • Posted on Jul 08, 2008
SOURCE: Dehumidifier runs but does not condense water.
It sounds like an issue with the control bord. This dehumidifier should have a 5 year warranty through LG. You will need to have this serviced. If it is under warranty by LG they will either refer you to a local repair shop and they will pay for the repair or they will replace it if you do not have a repair shop in your area. Call them and explain the problem to them. Make sure that you have your reciept. Here is the contact information for LG:
Toll Free Phone Number: 1-800-243-0000
Email: [email protected]
Keep me posted. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Anonymous
  • 121 Answers
SOURCE: LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Anonymous
  • 43501 Answers
  • Posted on Jun 05, 2011
SOURCE: Runs but does not dehumidify. Have run for hours
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
After 12 hours of operation, why is there NO condensate in the bucket?
units loose there efficiency over time , five years is a pretty good time for it to work
There is ice on the filter and the filter will not come out. Tried turning off so it would melt, but filter still stuck. It is summer so why is ice forming?
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I had mine ice up once or twice particularly on very high humidity days > 90%. Once it thawed out. I was able to remove the filter. Most likely it is due to dust getting on coils & condenser Or actually has a Freon leak. to resolve the dirty coils you can easily dissemble (that is remove front & rear cover) it to give coils and condenser a good thorough cleaning. It the coils and condenser are not at all dirty, then is not the cause of the icing. The units are typically not serviceable - i.e. a disposable small appliance.
1 1/2 year old machine runs but does not pull water from air
is the condenser getting cold at all? if not or only a little, you have a compressor issue. possibly no refrigerant. also check the air flow. if the fan isn't on, it'll just get too hot and water won't condense on heat.
Icing up on a dehumidifier
The gas can pass through the pipework slowly by osmosis especially after several years use. However, check fans, heat exchangers etc first before condemning unit.
1helpful
2answers
My Frigidaire dehumidifier no longer drips water into the bucket but drips oil. What happened?
You have a leak in the refrigeration system...that is why it is not cooling and condensing water and why it is dripping oil...
Here is a tip that I wrote to help people tofigure out what is going wrong with their dehumidifier
heatman101
The unit runs but does not collect water...it just runs. I've left it on for several hours. In the meantime, my basement is very moist with a lot of humidity from all the rain we've had. Even my...
the units low on refrigerant or freon,its normal for these to lose their charge after 2-3 years of use,i repaired a lot of these over the years,a couple of B.P.V.'s and about 9 ozs. of whatever type of refrigerant or freon and they will go another couple of years, all for about $50.00
1helpful
580.53701300 low temp dehumidifier freezes up, no water, fan & compressor run constantly in basement 61 deg. F. Has sensor been declared defective and will Sears remedy by free installation &...
Although, this was a poorly designed unit, manufactured by Whirlpool for Sears's Kenmore line, I'm not aware of any recalls due to a defective sensor. I can tell you, that although the air temp in your basement may be 61 degrees F, at floor level the temperature can be as much as 5 to 8 degrees colder. This definitely, would affect the operation of the dehumidifier. Also, a dirty or clogged air intake filter will cause the unit to freeze up. As will dirty condenser coils. Cleaning the coils twice a year, is recommended routine maintenance. And regular cleaning of the air intake filter is a must.
What I would suggest, is that you perform the maintenance mentioned above and move the unit upstairs where it warmer and run the unit there for several hours. If it collects water there, with the humidity extraction level set at 35%, then you will know the unit works as it should and that it needed the routine maintenance and the warmer air temperature. Do not perform any maintenance until the unit has completely thawed and the unit is unplugged from the wall outlet.
Hope this helps you to troubleshoot and solve the problem.
Machine works, but no water collecting
A dehumidifier is basically a cooler. The condenser coil on the outside should feel cold to the touch usually around 34 to 38 degrees, as air passes over the coils they collect the humidity in the air and it then drips down into a collector tray. If the coil does not feel cold it is ether a bad control switch not letting the cooler (compressor) turn on, low on freon, or burned out compressor
Compresser runs, no water is removed
You have a refrigerant charge that is "flashing" in the compressortor "pot" instead of in the evaporator. When it flashes in the evaporator, the latter gets cold and then the air going over it releases its moisture, it collects, and then drips into the pan.
If you have not had any work on the unit and have not had anyone mess with the refrigerant charge, it cannot be overcharged so I would assume at this point that there is some sort of obstruction inside the system that is causing the issue. Yeah, take it in for professional evaluation and repair. But if you had someone gas it up, there is too much in there.
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
