Dryers Logo
p
penny guin Posted on Feb 16, 2019
Have a Dyson blow dryer that does the same thing
Dyson Am04 model no longer turns on due to a power surge. What part is required to fix it? TIA.
First thing is to check the wall socket. Use a desk lamp or something similar and plug it into the socket you use for the heater. If the lamp works so does the socket. Next check the fuse. UK machine have a fuse in the plug, other countries use different systems.
If all these check out OK the surge may have damaged a circuit board inside the heater. Only a Dyson specialist could help you with that.
tip
Dyson Airblade Tap AB09 and AB10 - How to install (Official Dyson UK video)
How to install the Dyson Tap hand dryer - This applies to AB09 and AB10.
This video illustrates the key elements of the Dyson Airblade V hand dryer installation. It has been edited for time, does not show the entire installation process and is not intended to be a substitute for the printed installation guide supplied with the machine.
All electrical installation and repair work should be carried by a qualified electrician.
Please call the Dyson UK Airblade Helpline on 0800 345 7788 if you'd like any additional assistance or advice.
You can find out more about the Dyson UK Airblade hand dryer range by visiting http://www.dysonairblade.co.uk
tip
Dyson Airblade V AB08 and AB12 hand dryer - How to install (Official Dyson UK...
How to install the Dyson Airblade V hand dryer - this applies to AB08 and AB12.
1helpful
3answers
My dyson dc 25 sparks near the rotator roller attachment, what can I do?
Hi Cindy, it's Jack at Dyson.
If you can see sparking coming from inside the cleaner head, please do not continue to use your machine until we can help resolve this. It's likely the cleaner head will need to be replaced - once we've taken a few further details, we'll be able to confirm if this is covered under your Dyson parts and labour guarantee.
At your earliest convenience, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) for further assistance.
tip
Dyson Airblade AB07 and AB14 hand dryer - How to install (Official Dyson UK...
How to install the Dyson Airblade hand dryer. This applies to AB07 and AB14.
This video illustrates the key elements of the Dyson Airblade hand dryer installation. It has been edited for time, does not show the entire installation process and is not intended to be a substitute for the printed installation guide supplied with the machine.
2answers
MY DYSON DC27 TOTAL CLEAN VACUUM CLEANER HAS AIR BLOWING FROM AROUND THE BOTTOM OF THE DIRT BIN. IS THIS NORMAL
Hi Pamela, it's Jack at Dyson.
Underneath the clear bin is the exhaust outlet, where clean, filtered air is returned to the room after passing through the machine. This is totally normal and part of the machine's design.
I hope this clears things up, but if you do have any further questions please email [email protected] with your contact details, and one of our experts will be in touch as soon as possible. You can also find help online by visiting www.dyson.com/support
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
4helpful
How to blow up a mattress with a Dyson dc25
the Dyson upright does not have an exaust outet you can plug a hose into to blow up the mattress, I had the same problem and Dyson told me that basically you can't reverse their vacumme cleaners to blow up mattresses etc.
1helpful
Suction problems
One thing Dyson did recommend is to take an air compressor (or hair dryer) to the thingy in the collection reservoir. This seemed to help a little...
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Top Dyson Dryers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
