Crafts & Hobbies Logo
R
Robert Doerflein Posted on Feb 08, 2019
New DCC HO Loco has NO sound
New Loco 52404 HO 2-8-4 Nickel Plate #759. Changed address to 759 using B L address changer. Loco runs. lights work. no sound. tried to run on DC, still no sound. Is sound decoder same address as motor? I have not taken it apart yet.
Jeffrene Shand
Level 1:
Habit-Forming:
  • Contributor 28 Answers
  • Posted on Feb 21, 2019
Jeffrene Shand
Contributor
Level 1:
Habit-Forming:
Answers
28
Questions
0
Helped
4035
Points
68
Sound and motion decoder are the same address. Try F8 that mutes and unmutes the sound, If that doesn't work Change CV 8 to 8, that resets the decoder to factory settings. You will have to re enter the address as the decoder reverts to address 03. If all else fails check that the speaker is wired properly, if that doesn't work you may have a bad decoder that should be under warranty.
Good luck
1 Related Answer
Anonymous
  • 1116 Answers
  • Posted on Sep 23, 2011
SOURCE: 3975 Challenger only has idle
A couple of questions?
Is this a new product that you are programming or are you reprogramming an existing unit that lost it programming?
When you complete the programming, did you verify the programming was written to the chip and that the chip retained the update?
1helpful
Spectrum 2-6-6-2 dcc causing system short
Call Bachmann and ask them.
I did,and found them to be extremely helpful.
Here are some other ideas, if you wish to try them.
Take a piece of paper, not cardboard, but a heavier than normal weight, and cut pieces of it into shapes that will fit under the wheels of the loco and tender, and will cover the tracks
If you put a paper under the loco, and none under the tender, perhaps it is OK there, or, if you put paper under the tender, and none under the loco, perhaps it is OK there.
Try to isolate where exactly the short is.
God bless your efforts.
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Rear motored truck on kato ho p42 after dcc installation not working properly after period of time
I've had the same issue. I doubt it's your DCC hookup. Those motors are probably shot, and need to be replaced. I run analog, and I've had multiple motor failures with these things. These motors don't last long and, when one goes, the other one often follows... fairly soon after. I was able to prolong the motor life a little bit by orienting the motors to run the same direction. (I turned the rear truck around. I realize that's probably not possible, with your DCC in place.) I've still had motors fail, in spite of motor orientation. I've got all nine units, and six of the nine have had to have motors replaced. Some units, I've had to replace motors more than once! I haven't figured out any way to bring a motor back to life, once it starts stalling intermittently, or if it quits altogether. Sometimes, rotating the motor a tiny bit in its cradle might help, but that's a stop-gap. I suspect motor failure... unrelated to the DCC hookup.
1helpful
Have a lionel holiday tradition express. Lights are on, but train won't sing or go forward. Changed batteries and nothing.
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
I bought bachmann spectrum 2-10-2 loco just 2 days back. Its front heels and back wheels gets derails very often. I have many other locomotives and they dont give any problem on same tracks but this loco...
sounds like it's too lightweight! try running with a big blob of plasticine on top, to see of it runs right. if it then works ok you need to fill the internal spaces with lead (ask your local tyre shop for the weights they take off wheels when changing tyres)
4helpful
I have power to the track and the controller, but not the train.
I assume you have the Treetop Tender car on the track? The treetop tender is car that makes the electrical connection between the track and the train.
1. Use a volt meter across the track. You should have about 10.5VDC on the track (anywhere on the track)
2. Even without the Loco on the track, the Treetop Tender should light up if you have power to the track. If you have power and the tender does not light. Check the brushes located between the wheels on the tender. These are the motor brushes that pick up the current from the track for the train set. Make sure they are contacting the track.
3. Add the loco to the track and plug in the large black plug from the tender to the loco. Turn on the power and press forward. The train should start rolling.
Try all the functions, bells, ho ho ho, all aboard etc ..
Add one car at a time and make sure that each one lights up before moving on to the next.
Why wont my new Bachmann Ho train work. Light comes on, ALL track connections are re-done and great but still no fwd or bkwrd. Anyone???
Had the same problem. The loco would buzz, but no movement. Took the loco & controller to my local hobby shop for testing. Found out my loco was fine, but the controller had shorted out. Swapped it out & it's all good.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
