Choose Start, choose Settings, choose the Connections tab, and then choose Wireless Manager.
Choose the Wi-Fi button. If it is turned off, the button will appear as a lighter color and display an icon marked with an "X".
Choose Done.
To set up a Wi-Fi connection
Scroll to Wi-Fi and press ENTER. The device will detect available Wi-Fi networks.
Select the network you want to connect to, and then choose OK.
Select Internet or Work, and then choose Connect.
If you select a secure network, you may have to enter a network key that is provided by the network administrator.
To edit a Wi-Fi connection
Choose Menu, and then choose Wi-Fi Settings.
Scroll to the connection that you want to edit, choose Menu, and then choose Edit.
Make changes as needed, and then choose Finish.
To delete a Wi-Fi connection
Scroll to the connection that you want to delete, choose Menu, and then choose Remove Settings.
To change Wi-Fi settings
Choose Menu, choose Wi-Fi Settings, and then choose the Wireless tab.
Scroll to the connection that has the settings that you want to change, choose Menu, and then choose Edit.
Change any of the following information:
In Network name, enter a name for the connection.
In Connects to, select The Internet or Work.
If the network is a hidden network, which means that it does not broadcast its Service Set Identifier (SSID), select This is a hidden network.
If you want to connect directly to another device or computer, and not to a network through an access point, select This is a device to device (ad-hoc) connection.
Choose Next.
On the Configure Network Authentication screen, do the following:
Select the authentication and data encryption methods.
Enter the network key information or select the The key is automatically provided check box. If it is necessary, ask the network administrator for authentication, encryption, and network key information.
Choose Next.
Select or clear the Use IEEE 802.1X network access control check box.
To use Extensible Authentication Protocol (EAP) or smart card authentication, make the selections appropriate to your choice of authentication.
You need a password or a network key to piggy-back on someone else network. You can also contact your cellphone service provider and sign up for one of their data plan. This way you will have access to the Internet. Sorry if this answer is not even close to what you want.
The LTE indicates the phone network signal strength and not the Wifi signal strength. Go to your wifi setup and connect screen to see the Wifi signal strength.
You can try changing your connection to 4G and seeif you get a better connection in your area
Settings ->> Mobile Networks
change your WiFi security setings in your router from WPA/WPA2 to WEP.
Go back to the Smart TV and reconnect to your network with your selected security key.
It may be less secure but it may be the only setting your tv will recognize.
Open your dial pad and dial ##847446# a menu will come up select edit and a box will open, enter 10 zeros in MDN and 10 zeros in MSID then select "ok" the phone will restart then try activating again.
which windows are you using? Turn on your wifi and then For windows 7, go to the bottom right corner and press the internet connection icon and then select your wifi connection.
For windows xp, go to network connections and then to connect to a wireless connection
This can be so many things that trying to fix it by just reading the post, and without knowing if there was any changes, it's pretty difficult.
If the problem is that while searching for the network, the wifi don't see it, this could be the drivers or the wifi card.
If the information to connect tot he router is lost overtime, this could be a faulty memory RAM or the back up battery going bad.
Then again, the diagnose could be anything.
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
From the manual, here's what it says about cleaning:
And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
A wifi connection reverting to available could mean a wrong password enter or a wrong encryption type.
If the available wifi networks are being use as hotspot, then you probably needs to register in order to use the wifi network.
If it's a private network, check if the network is at band 5 or 2.4. Just some tips for you to check out.
