Maybe you can try to restore you iPhone/iPad.
Restore your iPad
If you can't fix the problem by rebooting your device, try restoring it with iTunes.
For more details, check: What to do when my iPad froze
Put iPhone X into DFU Mode and do a restore
Put phone in DFU and do a restore
SOURCE: my computer freezes up
Right click on a open spot on the desktop. Click on personalize. (that is with a left click)
Then click on screen saver
At the bottom of that window, is a link that says "Change power settings"
Click on that.
Change power plan.
Put Turn off the display - change that to NEVER
Put the computer to sleep - Change that to NEVER
That should fix your problem.
SOURCE: MY IPHONE IS FROZEN ON THE APPLE LOGO SCREEN
You need to a fresh restore of the iPhone. Hold down the home and power buttons together until the screen goes black. Then while the screen is still black, plug it into your computer WHILE holding down the home button.
At this point iTunes should detect your iPhone and tell you that you need to do a restore.
Hope this helps!
Please rate me!
SOURCE: jailbroken iphone 3g frozen screen
samevthing happened to me your gonna have to plugg your iphone into the comupter and hold the power and home button down at the same time until it shuts off. Keep holding the buttons down until it powers back on. there should be a picture of a guy wearing holding his hands up in the air on your iphone and itunes should open up on your computer. Now you will have to restore your phone.
SOURCE: Iphone 2g not starting back up after reboot..
When the device is locked up like this hold down the lock and home buttons. After a few seconds the device will turn off, immediately let go of both buttons. Now press down and hold the home button. Hit the power/lock button one time. Continue holding the home button until the phone boots up. It will need to be connected to iTunes for recovery at this point.
SOURCE: my iphone is frozen at the apple logo screen and
Press and hold Power and Home Button together for 10 secs and then release power button without releasing home button continue to hold home button (30 secs)
your phone will be in restore mode connect to iTunes after that and select your ipsw and then ....
Unlock:
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Reset the phone:
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
