It stops after 2-3 mins, but by placing some water inside before the program it will drain the water and do a 15 min pre wash. But it will not work through any other programmes. I'm sure the drain hoses are clear. The drain pump spins if moved with fingers from inside.
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
SOURCE: Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
SOURCE: bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
SOURCE: Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
SOURCE: dishwasher will not wash.
Ok, i recommend testing the circulation motor for its operational value. if the motor is functional, replace the main control board or timer.
