SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
SOURCE: Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
SOURCE: I just received the Swingline
I can solve it!!!!!!!!! Remove the clear tape at the front of the stapler...the tape you cannot see, and push from the back of the stapler! Please note on the bottom of the box......it reminds you that this stapler does not come with paper or staples!!!
SOURCE: We have a Swingline Giant
The triangular plastic section at the rear is the end of the staple tension/feed assembly. Grasp it, push inward and lift upward to release it, then pull it rearward and out of the stapler. Insert staples and reinsert the feeder and lock it in place again.. ready to go!
SOURCE: How do I open the
I couldn't open my Swingline Optima model 8784x either. Their website wasn't helpful except they mention you can change staples "with the push of a button." Button, I thought. What button? In the picture, there's a black button at the back end of the stapler. Mine is missing! The button, if it were there, would press down on a metal tab, releasing the staple slide which pops out the front. Insert staples, push it closed, you're done! I used a letter opener to push down the metal tab.
