Did you change the screen yourself? Check the speaker contact if properly installed or not. clean the contact
Testimonial: "Thanks. Took phone back apart and discovered damage to speaker cable. Getting a replacement speaker tomorrow to install. Everything else on phone works great. It was my first try working on this phone, so I’m not too disappointed with the result. It could have been worse. I had to move everything over The speaker is one of the easiest things to get and replace. I will be more careful in the future."
SOURCE: MTP Device Searching Preconfigured Driver Folders
I was having this problem as well, but solved it.
I, like others decided to just buy a USB cable for my VX9900 and use Windows Media Player for sync'ing. (I also have the Verizon Essentials program that I downloaded, but I like WMP better. No particular reason).
I was getting the installation messages and as soon as the MTP message came up, I got the "problem" message and it didn't sync.
What I did when I got the cable was to run the CD drivers that came with my cable. That may have been my mistake. I was bothered that the date of my driver was in 2005 since the phone came out late in 2006. So I looked at the name of the driver and it was something like C:\Windows\System32\Drivers\LGUSBDriver.xxx whatever... I went to my device manager and uninstalled the driver. I went to the C:\Program Files\ and deleted the LG USBDrivers folder. I went to the Windows/system32/drivers folder and there were three LG*.* files I deleted them. The next time I plugged the phone in and set it to sync, it worked. It's late and night and I may not have typed this really clearly, so feel free to contact me at bill (at) halfamind.com (because a half a mind is still a terrible thing to waste).
Bill Isles
SOURCE: Fake SciPhone 168+, Can not receive calls
calls are blocked, or do they jsut end when you answer, or somone else answers? if this is the problem you will have to turn the auto end off.Main menu => Calls => General call settings => More => Auto quick end = turn OFF
If the above menu path is not correct, then just look on your phone to find the General call settings where ever
they may be, as some firmware may have a slightly different menu system.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope.
SOURCE: My phone turns itself off when I try to answer or make calls !
you must have a lot of programs running in background , my solution is to hard reset it by typing *#7370# , your problem will be solved
SOURCE: Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
SOURCE: LG shine 8700 no sound coming from phone
lgShine 8700 , no ring sounds when i call out,but if i wait the person i am calling can still pick up.AND at the same time this happened there are no tone sounds when pushing buttons.I checked the volume setting and it is up to full
DKM
