My KIPOR KDE6000TA shows 48 Hz i do belive i can change Hz (to 52) with a Code to UP Hz
but i need the SERVICE CODE..
The KIPOR KDE6000TA has SHIMMER under
the DISEL PUMP.. IF!! you OPERATE it UP at 1000M and 2000M 3000M you remowe shims
(Cant remember MAX HIGHT.. )
TO add PRESIUR.. and RPM
Kenneth [Denmark]
Generator needs service, maintenance
Check the instruction book on your generator - for the exact steps to follow after this icon appears.
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
SOURCE: KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Testimonial: "Khan sb. truly is a professional. "
SOURCE: kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
SOURCE: KIPOR KDE6700TA no oil pressure, while
fill the sump to the correct level
check /replace oil level sensor system
