20 Most Recent Kipor Generator Diesel Kde5000ta Questions & Answers
Generator replacement brush notice:
1, from the model and material needs and the original brush.
2.It is best to grind the new brush to the Radian size of the old brush.
3. pay attention to adjust the brush grip pressure.
4. the carbon brush size should be equal, not too big or too small. The carbon brush is not subject to force in the process of placement.
5. pay attention to the carbon brush and armature to have obvious contact, do not push the carbon brush in.
Generator brush replacement method:
1, the first with a special wrench loose brush braid fastening screws, loose fastening screws should not be loosened excessive, to prevent screw loosening and falling off.
2, take off the carbon brush braid, the carbon brush and the pressure-equalizing spring at the same time. When installing a carbon brush, put the brush into the brush grip.
3, then press the equalizing spring.
4.Use special wrench to fasten the brush and braid to fasten the screw. When fastening the screw, it is not necessary to exert too much force to prevent the screw from being damaged.
5. Check that the brush moves freely in the brush grip, and the spring can be pressed in the center of the brush.
Kipor Generator... | Answered on Nov 01, 2018
Your question is general without specific details. Any one of many things will cause your generator engine to stop running.
Is this question about a Kipor KDE5000TA? If so, your generator is powered by a diesel engine. There are safety shut downs built into the generator to protect the generator head and engine. Do you have any fault codes showing on your control panel display screen? (Trouble codes P-01 through P-05 will be displayed if there's a detected fault)
If you have no fault codes, then you likely have a fuel problem. Do the obvious:
  1. Visually check the fuel level in your tank. DO NOT rely on your fuel gauge. It may be stuck or otherwise not working.
  2. If you have fuel, check your fuel filter. It may be clogged. If your fuel filter is good, you may have water contamination.
  3. Drain your tank and refill with fresh #2 diesel fuel. I use "Diesel 911" with a biocide to prevent water contamination and bacteria growth in my fuel.
  4. Make certain your fuel oil supply and return lines are clear, not leaking, and the fittings are tight.
I know I'm shotgunning, peppering the target. However, I don't have enough information to zero in on a specific area where the problem could be. Good luck!
Kipor Generator... | Answered on Sep 20, 2015
Start with the obvious first. Remove and clean your battery terminals and wire connections. Before you reconnect the battery, check your battery voltage across the +/- terminals with a meter. It should read 12 to 12.6 VDC. If it reads less than 11 volts, replace the battery. If the battery is good and the battery connections are clean & tight, you may have a faulty starter or a starter relay.
not being used that often you might need to clean the contacts in the solenoid and the starter
Kipor Generator... | Answered on Sep 02, 2012
I would try disconnecting the oil pressure sensor temporarily to isolate that circuit as the possible cause of it shutting down.
Kipor Electrical... | Answered on Apr 15, 2019
Give you some suggestion, hope can be helpful for you.
Here is some basic principles for troubleshooting generator faults:
1. Check outside of generator firstly then inside
In the case of generator failure, the possible fault locations outside the electronic control system should be checked firstly. This can avoid a fault that is not related to the electronic control system, but make complex, time-consuming and laborious checking on the sensors, computers, actuators and circuits of the system. The real fault may be easier to find but can not be found.
2. Code priority
Electronic control system generally has fault self-diagnosis function. When some fault occurs in the electronic control system, the fault self-diagnosis system will immediately monitor the fault, and alarm or prompt the operator through warning lights such as "monitoring engine". At the same time, the fault information is stored in code. For some faults, the fault code should be read according to the method provided by the manufacturer before the fault self-diagnosis system is checked, and the fault location indicated by the code should be checked and eliminated. After the failure code refers to the elimination of the fault, if the engine failure phenomenon has not been eliminated, or no fault code output is started, then the possible fault location of the engine is checked.
dsc01081_??-gchmaamodmqy1czm0regslps-1-2.jpg https://www.dieselgeneratortech.com/generator
Kipor Electrical... | Answered on Apr 12, 2019
check the instruction book on your generator - for the exact steps to follow after this icon appears.
Kipor Electrical... | Answered on Feb 10, 2019
screenshot_2019-01-25-14-07-29-5m4vg20v4mjgdjzqxftqb5de-2-0.png Qu'est ce qui provoque cet insident
Kipor Electrical... | Answered on Jan 25, 2019
If you are in Europe, you run 240 VAC @ 50 Hz. If you are in the U.S., you run 120 or 240 VAC both @ 60 Hz. Assuming that it's NOT an inverter generator, if your engine is running too fast or too slow, your frequency will be too high or too low which can damage sensitive electronics or electric induction motors. Apparently, you have a well controlled / monitored generator. While it is still running during those 20 seconds, I would check for your local voltage at it's output. If it is well above or below it's rated voltage, it's frequency will be out of range also, again, assuming that it's NOT an inverter generator. If it is an inverter type, you'll have to take it to a service center for adjustment. If not and the voltage is out of range, I would try adjusting the engine speed to bring it back into spec. I am in the U.S. My father in law had a craftsman 3,650 watt generator that didn't have the monitoring that yours does but it did the same thing. It would run for 20 or 30 seconds and quit. The oil was up and all looked well. I disconnected the low oil pressure switch and it ran fine. I replaced the switch the next day. I have a 7,000 watt Troy Bilt that I have wired into my house for emergencies but I bought a small, cheap Champion brand 1,400 watt generator for portable use. I brought it home and fired it up and out of the box it was putting out 133 VAC instead of the standard 120. I turned the idle down until it read 120 VAC and it works fine as long as I don't try to run a window A/C unit or fridge. It doesn't have the guts to start the compressor but it works great for lighting, TV's or small hand tools. Good luck.
Kipor Electrical... | Answered on Jan 03, 2019
press and hold the function button turn on the ignition and hold until it ges into test mode should display something like ph 2 then start it up and test the output voltage and wether or not it produces power correctly. if it does test the output voltage with a multimeter to confirm the output is the same as displayed on the machine if not remove the control panel and adjust the trim pot on the rear of the display panel until it displays correctly,
if not it could be the carbon brushes in the altenator or the avr which is a black box bolted to the frame
Kipor Electrical... | Answered on Oct 25, 2018
Kipor Generator Diesel Kde5000ta Logo
10 questions posted
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kipor Electrical Supplies
Most Popular Question
starter motor sometimes start other
  • Electrical Supplies
