SOURCE: B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
SOURCE: Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
SOURCE: Oven cuts out after ten minutes and comes back after cooling down.
The control switch on our AEG B3000, a similar oven, had burned contacts which prevented the fan from running in one selector position where the fan was to run when the heating element cycled off. The tech replaced thermostat which was not problem at all. If the fan does not run in this mode the heat stays at the top of the oven near the thermostat and prevents proper heat build up. Switching to 100% convection fan mode solved problem until switch replaced and all switch positions worked again. Hope technician will now refund for thermostat which was perfectly fine. Always check thermostat in boiling water before replacing.
SOURCE: AEG Microwave oven MC2660E - no power.
Hi , open open the microwave oven check the fuse , if open replace with the new fuse .
