20 Most Recent
AEG D2100-4 Electric Double Oven Questions & Answers
Can you please tell me
If you are just curious and its working turn on for 1 min then (after switching off) have a feel inside.
If it is opened follow the wires.
I have only used my large oven three times and
Use a Stanley (or similar brand) window scraper. Hold it firmly and always flat against the glass and scrape that browm muck away. Be careful not to let the points on either side of the blade to dig in as this will scratch the glass.
This type of cleaning is carried out on ceramic/halogen hobs so is ok to use on interior slass oven doors.
Hope this helps
AEG D2100-4 , THE TOP GRILL HAS FALLEN DOWN AND
Hi the spare part solution is to replace the oven liner. not economic and difficult to do. If engneering minded you can make a long slide clip i have made some out of an old oven shelf grid.forming a shape similar to a tent peg in shape and size and sliding it horizontally through the grill retainining bracket and hole in the oven liner. not easy to explain this but it works on aeg bosch and neff ovens with the same fault.
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
