You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
1) lube the deck belt, may you have a worn deck belt and sound very bad 2) lube the rollers bearing too 3) test the bearing from the main bearing , maybe is time to repair and replace. God bless you
1)Please lube the gear and shaft, very well from elevation motor 2) Test the motor, and replace if necessary.,see for ball bearing and lube 3) Lube the deck belt, and guide for instruction manuals. 4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it. God bless you
HI, Your treadmill have problem with the motor control board. The motor control IGBT is faulty thats why its stars at high speed and shuts off immediately by sensing over current drain. The solution is replacing the motor control board or replacing the IGBT on the motor control board. To replace the IGBT you should have a through knowledge in electronics. If you need any more assistance feel free to contact me through FixYa.
Typically you can tighten the belt with an allen wrench at the rear of the belt, treadmill be sure to align belt before tightening. Alternate each side as you tighten
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. After completing calibration of incline, press the Stop key and then remove the safety key.
