When I click my ASUS X Win 10 laptop notification icon to pair with devices AS PREVIOUS (I use ext.BT USB). It doesn't but connects with another small BT speak. Bluetooth icon is 'STUCK IN GREY' such that I can't turn bluetooth on/off. I've updated ALL driver yet it doesn't give me the option to turn on or off (highlight). I have tried troubleshooting hardware/bluetooth yet unable to identify why the bluetooth icon neither turns on but is seemingly permanently off.
Unpair jbl speaker in windows 10
then put jbl speaker into pairing mode
then on windows 10 pair speaker in bluetooth settings
then
test speaker to see / hear if it now works
Testimonial: "thanks"
Also try testing the speaker?
on pc #2, (THAT BT AND pair it)
if that fails,........... Think Battery. (good/bad/or only discharged)
Some speakers (BT tops list) have a battery to fail or not be charged
depends on the speaker brand actual model.
but the battery most be good and charges or BT will be dead.
some use USB to keep it charged (or precharge it)
or others have wall wart pack to do same before thaT TRIP TO THE BEACH.
happy trails
Testimonial: "thanks for the contribution"
if you solve this please tell how.
here is my list.(short)
battery in jbl charged (it is not solar powered)grin.(how IDK, id need to read your JBL manual.first.
PC#1 has internet now,
PC#2, does the JBL work on other pCs'?
assumed yes, to continue.
USB dongle on Pc#1 must have it's driver working. DM (device manager) and the USB PORT not DEAD try them all, some USB3 ports can fail.
due to missing drivers uSB3.
test the new dongle BT;usb now.
USB dongle, now test it on other BT devices,?
if the dongle proves good on other BT devices
last we....
now par the JBL to the new gongle usb BT
see it works, right?
there are 3 levels of drivers here
USB
BT
and the JBL
all 3 must be good or it fails
that is why testing parts on PC#2 is very important. to the cause real.
do not install the BT/DONGLE/USB
Until the internal Bt IS DISABLED
OR PROVED TO BE MISSING.
THE PC WAS SHIPPED WITH AND WITH OUT BT
mew (optional)
SOURCE: install ATK0100 driver first
You will need to install the update first, I found 3 versions of ATK0100. You can try all versions if you like starting with the latest version. Just remember to create a restore point before you install any of the drivers that you want to upgrade just in case anything goes wrong, you can go back to an earlier time when the system is working OK.
Latest Version :
Asus ATK0100 ACPI Utility 1043.2.15.61
Link :
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Asus-ATK0100-ACPI-Utility-104321561.shtml
Older Versions :
ATK0100 ACPI UTILITY v 1043.2.15.56
Link :
http://www.techspot.com/drivers/driver/file/information/7257/
ATK0100 ACPI UTILITY v 1043.2.15.49
Link :
http://modrv.com/other_devices/asus/2869prog.html
Note : If the links will not work, jsut copy the link and paste it to your web brower's address bar.
**For creating restore point, you can just go start>all programs>accessories>system tools> System restore. Just choose create a restore point and specify a restore name.
**The Drivers that are available are for Windows XP
SOURCE: Where can I find JBL platinum series speaker drivers?
Hi!
The kind of speakers usually don't effect what drivers you have to use. If you have your motherboard cd then you can install the sound drivers from that cd. And, if you still are unable to find them in the cd then please tell me the model no. of your PC(and/or model no. of the motherboard).
Please rate this solution as FixYa if found useful.
Thanks
Rylee
SOURCE: Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
SOURCE: Bluetooth does'nt work
Bluetooth] LG Notebook IVT BlueSoleil Bluetooth Driver Ver 2.1.1.0
http://www.notebook-driver.com/lg/lg-xnote-e500eb500ed500-notebook-drivers-for-windows-xp/
dowload here
SOURCE: IBM T43 Bluetooth not working
Press Fn+F5 then push "Turn On. Now your bluetooth device is turned on, connected and working. :P
Thanks a lot Larry. I have just edited the post with details
came with w10 ?,new,or don't know history.
had 8.1 then you installed w10?
as many did .
fist make sure device manager is clean?
if not your drivers were , attacked,(slammed)
also try some other Bluetooth device,
like head phones? to see if PC is ok.
device manager is inside control panel.
watch out for the new w10
it is very hard now to see thing that are disabled (a minor gray out) yellow marks would be better but they removed that nice feature.
the last w10 forced auto update turned things I had disabled.back on, (web cam ,is one)
so look carefully in DM
HWare is:
BT 4.0 support (on WLAN+ BT 4.0 combo card)
see 2nd from bottom w10 Bluetooth
https://www.asus.com/us/Laptops/X553MA/H...
but in all cases make sure DM is happy end to end, some things cross connect , like sound and web cams and others .
the big issues is doing w8 to w10 upgrade
1millions tried vast failed.
we do the upgrades with internet up
the fix the fall outs.
good luck to you and this JBL speaker.
thanks
or test BT with this>
https://www.walmart.com/ip/Bluetooth-Hea...
you're welcome
the above device needs to be charged
first with usb cable, to pC or charge usb adapter 5v to wall ac jack, (read manual how)
some only USB charge ,other have AC power packs
all this is in the manual to your device.
but check out DM first , no driver no joy.
the PC must have BT hard ware ,many do Not
the the PC BT DRIVERS MUST BE LOADED. NEXT
THEN THE BT SPEAKER, CHARGED (BATTERY INSIDE)
THEN THE BT MUST BE PAIRED
OK YOUR pc HAS NO BT
SO YOU ADDED ONE,
SO FIRST (AFTER CHARging battery in JBL
is to get the new BT USB dongle working
test it with other devices,makes huge sense
and make sure the new BT USB dongle shows up
on DM (device manager) with no errors
the with the BT USB tested to good on other devices , par it with the new JBL
also the PC must be internet connected first
or Pnp will be dead, mostly and for sure all new devices added, like BT and USB
and well most things.
is the PC internet connected???????????
PnP uses THAT mostly, (local PNP is very limited)
The laptop BT turned on icon is stuck grey (clicking doesn't turn it on) - solving that part will hopefully make the JBL speaker to pair and connect hopefully but how can it be turned on when it is seemingly permanently grey??
simple,that gray means the BT software is failing. and that can for 2 reasons
(usb & BT both) 4 counting HW and SW.
1:that USB POrt is dead (or drivers)
are all usb ports failing for the dongle.
2: the usb + blue tooth dongle is dead
3: the bluethooth driver is no good
so why not fist make sure the internet is working. is it that is always first first
for PnP plug and play
then look in device manager
see errors there?????????
any at all? any unknowns?
any with red or yellow marks
how old is that usb/BT dongle, 2009 made?
I guess your pc cam new with w10 or 8.1
but BT (spec)
this is missing on the wifi card.
so you got the dongle.
they made this for vast years,
Ive no idea at all how old is.
and many old ones have no w10 driver.
first horror is using the Asus BT driver
but not having the above wifi+BT card.
if missing , do not load the wrong driver.
then let PNP load the BT dongle
as you called BT-ext. (its usb,BT)
what makes this hard is no BT device stated
100s exist some in fact have no w8 or w10 drivers at all
one way to learn what is there is again
use DM. device manager.
or HWinfo32.exe portable (free)
in dm we get the Ven code and DEv code like this.
avoid this.asus BT driver, you dont have this guess, did you at your wifi card?
for proof the card is not BT? be 1st.
Version V12.0.0.9550 2014/05/2794.3 MBytes
see this. we can see all ID's on all chips relatedhttp://www.pcdied.com/DevMan/dev-ID.JPG
or use this.
hwinfo32http://www.pcdied.com/intel-magic/raw/ve...
this program is super good. and free .
allows you to see what is inside
why did you buy a USB /BT dongle.
the answer is,
hwinfo32 told me this is missing
missing BT but not missing cheaper wifi card.
there are only 3ways to id hardware.
1:; run hwinfo32.
2: open the wifi hatch read p/n (tell me)
3: ask asus to decode your PCs serial number
I cant do #3 im not them,.(secret list)
we can start over
why is the BT driver not working?
answer
why are you using the USB/BT dongle.>
first look at your wifi CARD
make sure its really missing first.
OK:
the book says turn off airplane mode first
or BT will not work (internal BT)
quote. page 65
Ensure that
"Airplane mode is turned off before enabling the Bluetooth connection of
your Notebook PC"
air plain mode kills them both dead,
and really is the same card.so...
but that means the BT must opted day 1new
with the wifi card.
asus.com has no parts pages , buy
nor any service manual with parts list
like dell or hp.
so finding your correct card for BT is hard.
x553MA (with A on end)
found them all.
3photos. to follow...
the list and both so called combo modules
if not combo, no BT there, easy,
this is the look method
then scans to find same. hwinfo32.exe
or tricky use of DM ,ID tab."VEN=?,DEV=?"
why did i look first
well if you have 2 BT in one PC that will fail.
that is why the are short ranged, to prevent
cross talk.(radio H3LL)
the flip side of wifi card also says
combo module , in print.
means wifi + BT.
on my PC the wifi card is under hatch.
the mobo wifi card is on the bottom of it.
i looked at mobo bottomm side
behind that long row of jacks. (usb ,etc)
ah bummer no hatch ! just found one for sale.
this is hard to do, lacking service manuals
nor parts list and parts views.
but there I did it.
I appreciate the support Larry - however, I use ext-BT HD becoz ASUS x553m does not have in-built bluetooth. I am still unable to the on/off button becoz the area is grey even after attempting the suggested.
