SOURCE: carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
SOURCE: the water is staying in carpets and is not being sucked back to the machine
The pick up slot across the front of the unit may be blocked or internal path for the water into the tank. Disconnect from electric and strip down the head and check for fibres/fluff balls - as these are the normal culprits. I am assuming that the suction motor is running?
Good luck
SOURCE: Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
SOURCE: bissell carpet cleaner does not have suction like it should
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have full suction once again.
SOURCE: Hoover Agility Steam Vac has no suction for the dirty water
it is a broken suction hose i had the same issue cleaned the whole thing then i opened it up and leaned it all the way back when it sits up right it sucks it up but when you pull it back to do your dirty work the hose seperates cause its broke
