Heating & Cooling Logo
Brenda Posted on Jan 20, 2019
I have a really old GE Furnace from the numbers on it I think it is a 1963 or 1973. The fan comes on but no heat. Everything in it is old and I most likely cannot find the parts. I cannot afford to buy a new unit right now. Is it possible to replace the heat kit with something more modern? Here is a picture of what it looks like.
Odd Furnace problem.
Its the afc fan comes on temp rise and goes off on temp fall
1helpful
3answers
Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2answers
Stopped heating yesterday...fan runs, but no heat... any parts available? Pretty sure is 120v ac.
Furnace Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/furnace-problems.html
Nov 25, 2015 - If your heater doesn't heat or works poorly, this furnace repair guide will help you troubleshoot and fix typical furnace problems with step-by-step advice. ... If your furnace's motor runs but the blower doesn't move air, the belt that ..... a tune upbut couldn't really find any thing wrong . last night and today when ...
Furnace Not Blowing Air? A Furnace Troubleshooting Guide
asm-air.com/heating/furnace-not-blowing-air-troubleshooting/
Dec 1, 2014 - A furnace works by a very simple principle, it uses some type of fuel ...This series of heated coils (called a heat exchanger) has a fan ... Today we will address the most common causes of a furnace not blowing air, and what you can do tofix it. ... It seems like this would be a no-brainer, but I can't tell you how ...
Simple Furnace Fixes ' The Family Handyman
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
I have air coming from the vents but no heat. The furnace is 23 years old and I've never replaced anything in the unit. Best guess? GE Intertherm. thanks
If the thermostat is set on Fan and not Auto the fan will continue to run. If the fan control is bad or is set at too low of a setting, it will blow cold air after the furnace has shut off. From what I guess of your explanation, your furnace is not producing any heat and the room air blower runs blowing cold air. You may have two issues happening. Make sure your thermostat is calling for heat by setting it to a high setting. Inspect the thermostat to see if it is set at Auto. Go to the heating system and inspect it to see if it is heating. If you can't view any flames carefully touch the exhaust pipe and see if it is hot. If not, you have a no-heat condition. A 23 year old furnace may need some TLC so call a technician you trust. He/she may need to replace the ignitor or thermocouple to get it going. They will also check out why your fan is running when it should not.
5helpful
2answers
Coleman Presidential II Model 7656A Mobilehome Furnace blower p
have you changed t-stat? if so you need to increase the heat anticipator. if you have a fan limit switch, the setting may need adjusting. Thay will change with age
2helpful
2answers
Bryant-Carrier Furnace Fan Stays On
I suspect a bad fan relay or bad fan control. Maybe the longer the control or relay is in the on position the more chance of it sticking on.
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
