SOURCE: hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
SOURCE: Wheel in Hoover SpinSrub turbine broke
The turbine is the only way to go. ther is no way to get that part only. Your only option to find a used one is to call on other hoover dealers if the have a box of used parts that fit your model.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: i cant get the brushes
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
SOURCE: Fairly new Hoover max extract won.t turn on.?
If you are lucky the cord may be broken on the vacuum or the cable may be loose in the plug. and it's not the motor which is burnt out.
Have a look at these tips, they apply to power tools but are valid for home appliances also:
http://www.fixya.com/support/r9189659-power_tools_not_starting_up
