SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
SOURCE: my toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
SOURCE: toshiba e studio 450 fotokopi yazıcı özelliÄ?ini nasıl kullanılır?
If u are running networking for your E450, make sure that printer driver is installed on your PC. If using SMB printing, u can edit the driver properties.
The driver can be download at below site:
http://www.copiers.toshiba.com/support/swdrivers.shtml
SOURCE: i am not install the
You can use Windows 7 Scan feature to scan a document or photo
If you have not installed the drivers follow the following steps.
Toshiba e-studio182 drivers are available Toshiba Official Support
Click 'Support & Drivers'
Choose B/W Copiers
Choose e-Studio 182
Select the drivers and download
Good Luck!
Appreciate generously if the solution could have been of any help!
CreativeTECH
SOURCE: resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
