First try cleaning earphone jack orifice then check your earphones for blockage I/E earwax ,dust ,dirt if this doesnt suffice,you can try the exstreme remedy "AT YOUR OWN RISK" go to settings select backup and reset,select factory data reset,then press erase all data...Remember you will have to setup your phone again from scratch. Marcus
SOURCE: motorola razr v3 - no hearing sound on ear speaker
Check the middle button on the side. Hold it in and raise the earpiece volume to the highest before you throw the phone away.
SOURCE: samsung e250 speaker problem
replace the flex must check ur flex year code like 2006 2007..... or try to replace ur earpiece...
SOURCE: There is a car symbol in display(place where ear
Just change the charging socket(charging interface).
SOURCE: Was unable to synchronize my samsung GT-C5212i
I have downloaded 3 times software form samsung for my Gt-c52112 i cell phone every time it says "The system cannot find the file specified" how do i sync my above mentioned phone to pc if not this do we have any better software to sync.
SOURCE: i want to use .jar files on my samsung GT-C5212i
In samsung we can not install .jar file directly... Samsung support the .jad format files.... to install the .jar files first we need to convert the .jar file into .jad format... for converting there are many many converters available in the market by searching in Google you will able to get the same...
After converting the .JAR file into .JAD file... now copy both the files into phone and run the .JAD file.... by following this method I am able to install the .JAR files on my Samsung S3500....
Hope this has helped you..
Please rate the answer..
Thanks...
