Building Materials Logo
A
Anonymous Posted on Jan 17, 2019
Centurion xtrac garage door motor - approx 3 y/o. The door does not want to open or close using the remote. motor give a long beep and the courtesy lamp flashes 3 times. What could be the problem?
I have tried all programmed remotes with the same outcome. Have tried the wall mounted pad with the same outcome. I switched to manual operation, open the door, closed the door all with the same results. There is no obstruction and the door operates easily in manual mode.
Steve Cox
Level 3:
Master:
  • Master 674 Answers
  • Posted on Jan 18, 2019
Steve Cox
Master
Level 3:
Master:
Answers
674
Questions
0
Helped
213314
Points
1718
Try to recode the remote opener.
  • 1 more comment
  • Anonymous Jan 22, 2019
    The same happens when you press the learn button, thus I cannot reprogram a remote receiver
    Tried pressing the run button on the motor itself with the same results
  • Steve Cox
    Steve Cox Jan 22, 2019
    The manual states the 3 flashes indicate an imbalanced condition and you should have a qualified technician look at this. Working on a garage door can be hazardous and you could be severely injured if you attempt to work on it without knowing how to deal with the considerable amount of spring tension that is present in a garage door mechanism.
    You can find the manual here:https://www.google.com/url?sa=t&rct=j&q=...
    or by searching for
    centurion xtrac garage door motor manual
5 Related Answers
Anonymous
  • Posted on Jun 28, 2008
SOURCE: Lift-Master garage door opener Model 1045-6 1/3 hp
There is a thermal cut out in the motor, usually the motor must cool before the opener will operate again. If the opener only operates 3 times it must be heating up too quickly.
First you opener is only made to do your job for you, which is opening and closing the door. If the door does not operate properly manually the opener will not operate properly.
When the door is disconnected from the opener it should lift easilly, it should basically stay at whatever point you let go of it (midway and fully open) and it should close without slamming down. It does not matter what size the door is!!! If it does not something is wrong with your springs and the door can be VERY DANGEROUS!!
With that being said it sounds more like a static lock-up possibly a loose ground or even a circuit problem in the home.
Bryan
Anonymous
  • 6 Answers
  • Posted on Dec 07, 2008
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Anonymous
  • 98 Answers
  • Posted on Jan 02, 2009
SOURCE: Remote will not operate garage door opener from outside garage
Will the remotes work in the garage? If yes but not outside with the door closed you might have radio interferace with your remotes. You might have to chage to a your reciever and remotes to a different brand (frequency). Sometimes it is less trouble to change out the operator. Chamerlain changed frequency from 390 (old) to 315 (new).
Anonymous
  • 3197 Answers
  • Posted on Jun 01, 2009
SOURCE: Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Anonymous
  • 3197 Answers
  • Posted on Sep 28, 2010
SOURCE: Hi, I have a Lynx 455
Check the sensors in the doorway. Sounds like they may be misaligned. They need to be pointing at one another to work properly.
Centurion xtrac motor relay clicks but not open or closing changed battries but still nothing what could be the problem
First check and clean the tracks the door runs in and the mechanical section that drives the door. This could be something as simple as a blocked or dented runner stopping the door moving. Try using all of the remotes and then try the wall mounted override switch. This will tell you if it is a remote or a door mechanism issue.
Is the 'Click' a single noise as you operate the door or a slow 'machine gun' style rattle? A single click suggests the motor itself isn't activating.
A repeating rattle suggest the drive from the motor is slipping and not shifting the linkage attached to the door.
Is it posible to program my Centurion D3 remotes to open an E.T MK111 garage door motor
No. It's not possible. There is no setup codes to synchronize with.
1helpful
How do i program my garage door to open with my car garage opener button
Push and hold the two outer buttons until the LED flashes fast Approx (15 seconds) then hold your garage opener up to the mirror or visor and push and hold any button 3 or 4 seconds on the opener Now the Home Link is programed. With the car safely away from the closing garage door find and push the garage openers red programming button (on the motor assembly somewhere that gives you about 30 seconds to push your cars home link button so the garage opener learns the button you want to use for that door the other two buttons can be programed for other doors or house light controler gate opener in the same manner
I need to know how to programe extra remote for my centurion D5 moto gate
If you Google Centurion D5 moto gate you will find a video listed that shows how to do what you need.
My centurion garage door is not working correctly. the remotes will not open and close the door, and the door will not operate correcly when the red button onthe control unit is pressed. when it does...
Centurion Systems: (you will have to C&P the full URL shown below)
There are only two systems of door opener, XTrac and RDO.
Manuals can be found here: (Page down until you see the appropriate section.)
http://www.centsys.co.za/?q=con,114,Product Documentation
Note that the driven shaft requires periodic lubrication.
Although most systems should be lubricated with Molybedenium disulphide grease (applied manually), I find that a small amount of spray oil every 6 months works wonders.
The shafts can and do aquire dust, and this can cause the load on the drive mechanism to exceed limits. If lubrication does not solve the problem, then you may well have a drive unit failure, requiring repairs by the manufacturer.
Note that NO lubricant should be applied to the steel door guides.
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Top Building Materials Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Building Material Expert? Answer questions, earn points and help others
