SOURCE: Trilogy dl 2700 serries digital lock program managers code
First you need to know if you have a standard 2700 or the new enhanced version, it makes a big difference. Press any 2 buttons then star, if you get no response it is a standard version, if it beeps several times it is the new version. If it is the standard version, disconnect the battery and press any button. Now you are at factory default. Reprogram the master code, remember the master code and the operating code must b e the same length. 12345 A 1 A new master code A new master code. The master code is the only code that needs to be entered twice during it's programming. To set a manager code press; master code A2A new manager code, to set a new user code; enter master code or manager code A11A new user code. The programming must be done during the lock's unlock window so write down the procedure you intend to use to make things go quicker, if you need more time you can change the unlock window, it is probably set at the factoy 5 seconds. Press master code A45A4, this will give you a 20 second window to program the lock, when you are finished change the lock back to 5 seconds, press; master code A45A1, keep the open window short to conserve batteries.
SOURCE: Liftgate issue not allowing me to lock/unlock vehicle
If the key doesn't work on the driver's side door, then the vehicle had the driver's side dor replaced, and whomever did the repair, failed to remove the door lock assembly from the old door and swap it out with the "new" door. This only happens when the door is taken from a wrecked vehicle and used as a replacement. You do not get doors from a factory with the lock assembly in place.
Take the vehicle back to where you had it repaired and tell them that it is thier fault that your vbehicle remote locking system fails. They did not set up (adjust) the switches correctly.
SOURCE: VW Jetta GLI Drivers Side Door Lock
If this happen to others check with VW to is if there is a recall on it. You can also check on the Web to see if there is a recall on it. If there is VW will fix it free.
SOURCE: I have a toshiba 62HM95 DLR TV. I was advised by
This could be a sign of the color wheel failing. This is part of the light engine assembly and is not sold separately as far as I know. My most common source lists the light engine as out of stock. (The last quote I had was ~$600 for the assembly.)
The cooling fans can also cause a noise as they fail. However, the red light would be blinking in that case.
I hope this helps.
