This error occurs when the cartridges are jammed by some packing material. It may also stem when the cartridge is not installed properly. The Epson printer also displays this error when the setup is not implemented accurately.
Method: Manual Method
>>Inspect the printer to check whether any scrap of paper or alien object is jammed in its parts
>>Ensure the cartridges are installed properly.
>>Remove the cartridge and see whether some object is etched on it. If that happens to be the case, with utter care clean it.
>>Insert the cartridges in their correct position.
>>Switch on the printer and try a demo print. Check whether the error code has vanished.
>>This step is tricky and needs adroitness to be executed properly. If the manual method doesn't work, try the other 2 methods enlisted below.
Follow this link for more methods: Epson Printer Error Code 0XEA.
SOURCE: I switch the printer off and now it doesn't want switch back on. Epson L565
I think there is an issue with the power button.. Go to your nearest customer care branch or call them.. Epson Printer Tech Support Phone Number Epson Driver Support
