SOURCE: Washing Machine Problem
transmission or timer is bador going bad,or there is a switch i have an old whirlpool and roper which is made by whirlpool/kenmore that does same thing hope that helps its at least a start
SOURCE: started the washer and then it stopped and machine
Try pushing the basket to the back so you can reach the lid switch housing - you should be able to re-align it by hand.
If that is impossible, that means the lid switch plastic housing broke loose and needs to be replaced.
I would need a model # so I can help you with instructions.
SOURCE: error code 49 on gw712
Ive been told that this is a faulty cold water valve. Just got of the phone with F & P as my machine is doing the same. Bout $60 to replace
SOURCE: lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
If the lid is not locking, then it could be the electromagnetic door catch, Check the power switch, on the machine, then check the carbon brushes and the motor.
