SOURCE: Kenmore dryer 110 708 12990 Igniter glows, but
replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
SOURCE: How can i do to change 220 volt to 110 volt my GE
I never heard that one as of yet. The two 110 lines are for separate circuits. One for the dryers controls and the other for the heating element only
SOURCE: ge profile dryer how do you get to the burner? ge
Since you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
