D
Dick Lamb Posted on Dec 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IPod third generation 3g won’t connect to 2019 Honda Pilot via USB. Screen indicates Unsupported device.
Level 3:
  • Apple Master 19,187 Answers
  • Posted on Dec 28, 2018
Apple Master
Level 3:
Answers
19187
Questions
0
Helped
4346390
Points
82261
You are not likely to be able to use it with that vehicle, That version of IPOD is 16 years older than you car. There wont be drivers available for it. You cannot change the car system, you may be able to get an audio jack if the car has AUX in.
john h
Level 3:
Top Expert:
  • Apple Master 29,494 Answers
john h
Apple Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7561125
Points
193449
5 Related Answers
Geoff
  • 562 Answers
  • Posted on May 29, 2009
SOURCE: ipod shuffle 2nd generation is not responding
Have a look here at the Apple website
http://www.apple.com/support/ipod/five_rs/shuffle2gen/
ipodslinger
Steve Brown
  • 688 Answers
  • Posted on Jun 05, 2009
SOURCE: connected screen is all i can see on my ipod nano
press and hold the menu and center buttons for 10 seconds you will see the apple appear and the ipod will reboot
Anonymous
  • 742 Answers
  • Posted on Oct 21, 2009
SOURCE: connecting the sciphone i68 3g via usb to the computer
Find i68 drivers here.
Anonymous
  • Posted on Mar 16, 2010
SOURCE: My Pioneer car stereo recognizing the songs on my IPod 3G
I had this exact same problem. Here is how I just figured out how to fix it. First of all, my friend as an iTouch as well, so I plugged his iTouch into my DEH-P4000UB, similar to your 3100UB, and it actually worked and played music. So I went to my Music then selected a song and pressed pause. I turned on the car and then plugged the USB cable into my iTouch, exactly the same as yours. When I replugged my iTouch into my deck it gave me a different error this time, Error-19. Refreshing but still frustrating. So I turned off the car, unplugged the USB cable and tried it one more time. This time I selected "Repeat" on the song, don't ask me why, but this is exactly what I just did. I turned on the car, plugged the USB and it worked!!!
I understand your frustration and I've been dealing with it for a while now. So hopefully this helps. Good Luck!
Anonymous
  • Posted on Dec 14, 2010
SOURCE: I recently bought a Edimax
hey, can you please share how you got this working? I am having same problem.
Need to download iOS 5
to update to iOS 5 is only possible on iPhone 3GS / 4 / 4S with connecting the device to iTunes on a computer.
- Plug the iPhone to your computer and open up iTunes under devices click on your iPhone and then click on check for update.
latest iOS possible:
iPhone 1 = iOS 3.1.3
iPhone 3 = iOS 4.2
iPhone 3GS = iOS 6.1.6
iPhone 4 = iOS 7.1.2
iPhone 4S = iOS 8.1.2
iPhone 5 = iOS 8.1.2
need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-0.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-2.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-5.jpg
Mar 19, 2014 • Cell Phones
1helpful
My computer nor itunes will detect my ipod. Whay can i do?
HiTerry
First, make sure your iPod is fully charged and then toggle the Hold switch on and off.
Reset, Retry, Restart, Reinstall, Restore
Go through the 5 R's of iPod troubleshooting, which will often solve your issue. If you're still experiencing the issue after going through each of the steps, then continue for more suggestions.
To determine if your iPod syncs via USB or FireWire, check the table in the Additional Information section below.
Tip: If you are using Windows XP and have recently installed a Service Pack, check the Device Manager. Click the Start menu and click Run. Type "devmgmt.msc" and click OK. If no devices appear in the Windows Device Manager, go here.
Still can't see your iPod?
Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below-you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing.
Make sure your computer meets the iPod system requirements
Make sure that your computer meets the system requirements to use iPod with Windows.
If your iPod displays an exclamation point folder or sad iPod icon
If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue.
Charge the iPod and make sure it is getting power
Your iPod must have enough of a charge for your computer to recognize it. Connect your iPod to its power adapter or to a high-power port on your computer to charge your iPod if the battery is depleted. If your iPod is connected through FireWire but isn't getting power from the FireWire bus, your computer may not recognize it.
Secure the iPod's connections
Make sure that there is nothing physically inside or blocking your computer's USB (or FireWire) port, and that the cable connections to your iPod and computer are secure.
Note: If you're using an iPod shuffle (Second Generation), make sure the iPod is inserted securely in the iPod shuffle Dock.
Restart your computer
Sometimes simply restarting your computer can resolve issues.
Connect iPod to a high-powered USB port
If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer.
If you're connecting the iPod to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. Also, see iPod not recognized when connected to Windows laptop over USB to be sure that your USB ports are supplying enough power.
Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer.
Avoid connecting the iPod to a USB hub. Connect the iPod directly to a USB 2.0 port on the computer. If a hub must be used, make sure the hub is USB 2.0, and that it has its own power supply. Also, make sure the hub is connected to a high-power USB 2.0 port on your computer.
If the issue persists, try disconnecting other USB devices from the computer such as printers, cameras, scanners, external hard drives, and USB hubs to determine if there is a conflict in the USB chain.
Check whether your iPod's cable functions properly
Make sure that you are using the cable that came with your iPod. Some third-party cables may not work properly with iPod.
Make sure that nothing is in or blocking your computer's USB or FireWire port.
Check the connections to make sure that the cable is completely plugged in.
Try another known-good FireWire or USB through Dock Connector cable if available.
If swapping out your old cable for another resolves the issue, then your original cable should be replaced.
Place the iPod into Disk Mode
Try placing the iPod into disk mode to see if it is recognized by iTunes, or My Computer.
Check which format iPod is in
iTunes for Windows only recognizes Windows-formatted iPods. You cannot use a Macintosh-formatted iPod with a Windows PC. To learn for which platform your iPod is formatted, follow these instructions.
Check whether your computer's port functions properly
If another FireWire or USB port is available on your computer, try connecting your iPod to it.
If your computer recognizes your iPod after trying a different port, the original port could be faulty.
Note: iPod will not automatically wake up if you connect it to a 4-pin FireWire port. You must press the Select button (the wheel's center button) on the iPod to wake it from sleep.
Check if Windows confuses iPod with network drive
If the drive letter after iPod ("E" in most cases) is mapped to a network drive, both Windows Explorer and iTunes may exhibit strange behavior in relation to the iPod (including preventing iPod from appearing. See "Windows confuses iPod with network drive and may keep iPod from mounting or songs may seem to disappear" for more information.
Your USB or FireWire card isn't recognized by Windows
Make sure that Windows recognizes your USB or FireWire card. Follow these steps to find out if Windows sees your card.
Third-party software may be causing conflicts
Some third-party software (such as security software) may prevent your computer from recognizing your iPod.
Try adjusting the settings of such software, or temporarily disabling it, to see if that resolves the issue.
Also, try booting Windows to Selective Startup mode to disable any third-party startup programs and services, and isolate which software may be causing the issue.
Install or reinstall iTunes
Download and install the latest version of iTunes.
In some cases, you may need to completely uninstall and reinstall iTunes.
Make sure FireWire card is a WHQL-certified IEEE 1394 card
Only certain iPod models sync via FireWire. Refer to the table in the Additional Information section to make sure your iPod can sync via FireWire.
If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod.
If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this:
Go to the Windows Hardware Compatibility List website.
Click on the link that corresponds with your Windows Operating System to view the compatibility list.
Select your Operating System build, and then from the Product Categories pop-up menu, choose 1394 Controller.
Click the Search Now button.
You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP (Apple sells FireWire cards that are compatible with iPod at the Apple Store.).
To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it.
Check for a conflict in the FireWire chain
Your computer may not recognize your iPod if there's a device conflict in the FireWire chain. To see if this is the case:
Disconnect all devices from your computer's FireWire ports.
Connect your iPod to your computer's FireWire port.
If your computer recognizes your iPod, you should troubleshoot for FireWire device conflicts.
There may be an issue with your computer
If another computer is available, verify that the same issues happen with the other computer. If the other computer recognizes your iPod, you may want to troubleshoot for issues with your original computer.
If after following these steps your computer still doesn't recognize iPod, see the iPod Service website to arrange for service.
Please Take Time To Rate Me
Bud
4th generation i pod not reconizing
Hi james
Your iPod needs service
Bud
Don't detect when i connect to computer
Tip: If you are using Windows XP and have recently installed a Service Pack, check the Device Manager. Click the Start menu and click Run. Type “devmgmt.msc” and click OK. If no devices appear in the Windows Device Manager, go here.
Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below—you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing.
Please Rate Me
7helpful
Ipod shuffle want connect to the computer
Please Rate Me
Ipod touch 32G 3rd gen is not recognised by windows when i plug it in windows gives message, USB Device Not Recognized
Its a little lengthy but worth the read:
Please Rate Me
New itouch, downloaded apps will only open for a second. help!
Before I begin, I must state that my expertise is limited because of the small amount of details you have provided. I will post my best solution now, but please show more detail in the future.
I am assuming if the iPod touch is new, it is a 3G (third generation, not to be confused with the 3G data network). Either way, my solution would be about the same for the 1G, 2G, or 3G. I own a 2G right now.
The "only open for a second" problem is called "crashing". The fact that it is crashing could mean that you need the most security, available in Apple's latest software updates. Please try to download the latest update by reading the below instructions:
If you haven't already, please download and install the latest version of iTunes from www.apple.com/itunes . Then, plug your iPod into the computer via the USB cord that came with the iPod. After iTunes and your computer both recognize it, click on your iPod in iTunes. Then click Check for Software Update to download and install the latest iPod touch software directly from Apple for the most security.
Cheers and good luck,
DMKlunk
Unsupported docking for Nano Chromatic
Your docking stations support the previous generation nanos but not current. If you can, return the docks otherwise you'll have to fork over the cash for a new one.
1helpful
Registering & Syncing Ipod Nano 3G
try reformatting the ipod. that might reset it.
Apple iPod, Third Gen
has to be one of two problems,see if you can borrow usb lead to rule this out,but more than likely either bent pins or loose connector on ipod itself.rule out lead before bringing for repair
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
