Lasern wireless mouse with right and left buttons working. Scroll wheel turns but its like not connected. Can it be cleaned
SOURCE: Scroll wheel function issue VX Nano Cordless Laser Mouse
what is your serial number and model number (PID and M/N, found inside battery compartment). some mice had a recall, and there is a list which has been taken down, which i downlaoded onto my computer.
SOURCE: Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
SOURCE: G9 Laser Mouse Scrolling Problem
thx for helping dude, logitechexpert my ***...
now check that...i was so pissed because of such stupid advice that i hit my mouse on the corner of my desk...yep i really did.
...and then it worked! it SCROLLS!
my theory: the logitech has a quite complicated mechanical clockwork-like gear switch for their scrollwheel. they are so proud of it, that they even have pictures of it on the box when you buy a g9. well, i guess when you make things more complicated they arent that reliable anymore...like the gear switch at your bycicle which gets messed up sometimes, because its small mechanical parts just get stucked.
so my mechanical solution: turn your g9 around hold it and knock three times(not too soft: imagine the money you paid for this mouse and release your anger) just around the area where the mechanism is located...i had exactly the same problems like you and now it works perfectly!
...i guess i dont need to buy batteries.
SOURCE: Scroll Button does not work
Take the mouse off of the computer. Turn it upside down on a piece of clean printer paper, so that the scroll ball is touching the paper. Roll it around briskly on the paper. This will help clean off the scroll ball.
SOURCE: HP Optical Mouse right click button does not work
i've a usb mouse and r.click is not working
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Or disconnect the mouse from your computer restart.
If still does not work you need a new mouse.
hope this helps
