Microwave Ovens Logo
T
Toni Posted on Dec 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Samsung miicrowave the display light went dim hard to read
William Miller
Level 3:
  • Samsung Master 9,179 Answers
  • Posted on Dec 28, 2018
William Miller
Samsung Master
Level 3:
Answers
9179
Questions
Helped
4481737
Points
21747
I would need to know the full model number.
Feel free to contact me directly by email if you prefer.
- Ed
[email protected]
http://www.microwavecontrol.com
My Oster OGB81102 microwave oven's display is too dim. Is there any way to brighten it?
Behind the display module there is a capacitor. It needs replacing. They bulge, split and fail.
Display on control panel is dim and hard to read.
If it's an LCD or LED display, it' may not be getting an adequate voltage from its driver I. C.. If fluorescent, it could be failing itself, or not be driven properly as well.
Based on other posts on this site,
The going rate for repair of these circuit boards seems to be about $39.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
1helpful
Display works well but is very hard to read even in the dark.
UNFORTUNATELY THIS IS A COMMON PROBLEM..THEY HAVE 2 SEPARATE LIGHTS IN THESE DISPLAYS AND ONE HAS WENT BAD...UNLESS YOU CAN SOLDER AND FIND THE REPLACEMENT LIGHT BULB THE ALTERNATIVE FIX IS TO REPLACE THE DISPLAY CONTROL ON THE UNIT....PLEASE VOTE...GOOD LUCK TO YOU
1helpful
The time display numbers are very dim and I can hardly read them.
There are two main causes for this dimming:
1. Dust & other particle buildup on the front of the display glass and the rear of the display window. This can be cleaned.
Cleaning the display is easy, but you need to be careful so you don't break the glass.
First you would unplug the microwave or turn off its breaker.
Then see the video here that shows you how to remove your control panel assembly in less than 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the plastic frame.
Then carefully (since the display is made of glass) remove your circuit board.
Using a soft cloth (since paper towels can scratch) lightly dampened with non-ammonia cleaner (since ammonia can damage some polycarbonate plastics), gently wipe off the front of the glass.
Then gently wipe off the back side of the plastic display window in the plastic control panel frame.
Reassemble, reinstall, and power it up, and it should be brighter, sometimes a whole lot brighter!
If that does not brighten it up enough, then...
2. Your vacuum display tube is wearing out and either the VFD display tube or the whole control circuit board must be replaced, depending on your model number, which you didn't mention.
If you'll contact me with your model number, I can give you an estimate and free do it yourself info.
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
R-1751 display issue and the work light is on always
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
