II just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site: http://SalaryHD.CoM
SOURCE: I recently purchased a Panasonic
Download user manual of DMR-ES20 by clicking on Panasonic Support.
SOURCE: need universal code
Try using any Funai codes in your list; no promises but you may have some luck.
SOURCE: have ibm2668 thinkpad has old pass code can't get in it.
I think this is bios pass? There are two ways - shortcircuiting bios pins or parallel method. Anyway you must disasemble your computer. Try to remove bios battery first (its under keyboard) for two hours. It's a very small chance this will help. When removing battery does nothing, you must search on google which bios pins to shortcircuit in your model. Problem is if you don't have manual/tech scheme for your machine. Try to download it from manufacturer website. You can use a parallel method, but it is harder. Shortcircuiting really works, one guy on fixya was fine with bios pass. Wish to help you more, but I cant, I have the same problem with Fujitsu Siemens, and so on, no solutions, no tech scheme :(
Finally you can use a universal and manufacturer password, search for these two, For universal, you must check what kind and version of bios you have. It usually shows when you just starting computer.
SOURCE: I need to reprogram the remote. Purchased a floor
The remote cannot be reprogrammed to operate the SC-HT70 as all functions are already set. If your remote isn't operating your equipment as expected then the chances are the remote has become faulty.
The remote can be programmed to operate other equipment as detailed on Page 42 of the manual below.
http://service.us.panasonic.com/OPERMANPDF/SCHT70.PDF
