Question edited for correct spelling of the maker.
Question moved to maker category.
Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear.
Push a flexible net curtain wire down the drain until it appears above the compressor pan.
You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking.
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
the fridge probably isn't quite level - or tilt the side that is holding the water slightly so it down to the drain hole - 1/8" could make the difference
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
