20 Most Recent Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Questions & Answers
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
6/19/2020 3:32:21 PM • Liebherr KGBN... • Answered on Jun 19, 2020
Leibherr fridge freezer makes intermittent buzzing noise
It is quite normal. No problem at all.
8/29/2016 3:17:24 PM • Liebherr KGBN... • Answered on Aug 29, 2016
My fridge is not cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
4/15/2016 1:19:52 PM • Liebherr KGBN... • Answered on Apr 15, 2016
Water flows out of the upper refrigerator
Sounds like the drain hole is blocked with either ice or food, defrost completely, access drain hole clear with hot water.
12/2/2013 10:14:10 AM • Liebherr KGBN... • Answered on Dec 02, 2013
0answers
Hi we have a liebherr premium biofresh fridge and
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
9/19/2011 12:58:23 PM • Liebherr KGBN... • Answered on Sep 19, 2011
2answers
Stainless steel finish on Liebherr fridge
if you have scratched or damaged the surface, you can get a stainless steel foil product to cover your refrigerator from www.applianceart.com. If its not that bad, make sure you are using a stainless steel cleaner after you have washed it with a regular cleaner.
7/19/2011 11:56:46 PM • Liebherr KGBN... • Answered on Jul 19, 2011
Liebherr bio fresh fridge/freezer model
This ice maker can be cycled manually to help determine the problem. To cycle this ice maker, pull the front cover off of the ice maker. You will now have access to the module which has some test terminals marked on it (I'm sending you a picture). Using a well insulated jumper, place it between T-H and the ice maker should start to cycle.
Be careful this is a hot (live) check. If the ice maker starts, after about 5 seconds remove the jumper. It will take a few minutes for it to break the ice free and if it cycles completely and refills the ice maker will need to be replaced. This indicates it's not starting on its own. If it just stops on the ice, the mold heater may be open. You should be able to feel the bottom of the ice maker to see if it's getting warm but be careful, if you touch the mold heater, it can be very hot. If the mold heater is not hot, again the ice maker will need to be replaced. If the ice maker never cycles with the jumper, there may not be any voltage getting to the ice maker. Some voltage checks will need to be made and a technician will be needed to make these checks.
Hope this helps.
11/15/2010 3:42:34 PM • Liebherr KGBN... • Answered on Nov 15, 2010
2answers
I need urgent assistance in
I suggest you switch off for about 12 hours and do a proper defrost and retry again. 90% of the time thats all thats needed.
9/7/2010 4:53:31 PM • Liebherr KGBN... • Answered on Sep 07, 2010
I accidently pulled my freezer drawer out and it
You can contact the Company at this link for Service and Parts;
http://www.liebherr.us/HG/en-GB/96685.wfw
7/18/2010 1:10:43 AM • Liebherr KGBN... • Answered on Jul 18, 2010
0answers
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
Popular Tags
42 questions posted
Top Liebherr Refrigerators Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Ngoro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
fridge bottom freezer working
  • Refrigerators
