Winter Sports Logo
k
kris roelofs Posted on Dec 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2007 polaris switchback 600 belt failure Only getting about 20 hours out of my cvt belt Shreds belt from the outside edge
Julian Wainwright
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Dec 08, 2018
Julian Wainwright
Expert
Level 2:
Sergeant:
Answers
205
Questions
0
Helped
180134
Points
614
Check that all of the pulley wheels and tensioner don't have any defects in the running faces.
3 Related Answers
Anonymous
  • Posted on Jan 24, 2010
SOURCE: 2004 Polaris 600 edge touring Perc reverse not
check your engine idle speed..if idling too low it will not engage also check your belt deflection if too tight it will cause the engine speed to be too low causing the no reverse condition
Anonymous
  • Posted on Feb 22, 2010
SOURCE: i need to find the location of the fuel shut off
its right before the fuel pump on the recoil side
Anonymous
  • 4803 Answers
  • Posted on Feb 03, 2012
SOURCE: 96 Ram V6, changed the power steering pump and now can't get the belt to line up, fraying on the outside edg.
Hopefully, you did not install the pulley on the pump upside-down. (I have seen this happen before) Otherwise, the end of the pump shaft should be flush with the flange on the pulley. If it is off just a little one way or the other, it can cause fraying and severe belt noise.
How to fix a P16A8 CODE on 2015 600 POLARIS ADVENTURER SWITCHBACK
P16A8 This Trouble Code sets if the Injector Output Supply 2 Voltage is below an acceptable limit. Can be caused by Damaged Wiring or Faulty/Shorted Connectors.
ECU Output Supply Voltage
Nov 17, 2018 • Polaris ATV
My 2014 600 switchback won't idle down past 4000 rpms it still runs but not like it should
Have you had the valves adjusted recently? If so.. the intake valves are way too tight..... if not, you may have a gasket leak in the intake tract somewhere... even a head or base gasket could be the culprit...
Jan 08, 2017 • Polaris ATV
Why would my Polaris snowmobile overheat?
My sled overheated - HCS Snowmobile Forums
www.hardcoresledder.com > ... > Rush/Switchback (Pro-Ride Chassis)
Jan 6, 2013 - 12 posts - ‎3 authors
Hey guys, I was out riding my sled yesterday, and out of no where, it threw a code, and it went into limp ... I would be worried about where did the coolant go? ... (Knowledge + results / corrected HP)Polaris + Als input = WGAF ... overheating
Feb 23, 2013
05 Polaris Switchback 800 overheated
Dec 23, 2010
Overheating...
Dec 23, 2008
2001 xc 600 overheating
Nov 29, 2006
More results from www.hardcoresledder.com
02 800 rmk overheating - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris-snowmobiles/67778-02-800-rmk-o...
Mar 4, 2012 - Does anyone know where I can get free service manuals for my sled so ... for a 05 polaris edge touring but i have used it to fix my 02 edge 600. Edge 600 overheating
Jan 2, 2013
Snowmobile Overheat Problem :( F8 LXR
Jan 16, 2012
2000 touring 600 overheating
Jan 13, 2011
need help with overheating issue
Nov 20, 2005
More results from www.snowmobileforum.com
800 Pro RMK, overheating, coolers... a
How can I get better performance and gas mileage with my 2015 polaris switchback 600 pro S?
2015 Polaris 800 Switchback Pro-S Review + Video
www.snowmobile.com > Reviews > Polaris
Sep 11, 2014 - 2015 Polaris 800 Switchback Pro S Review Video: Polaris 2015 800Switchback Pro S is the right choice for the vast majority of us If you can get one itwill ... or Pro-X - the new AXYS chassis Pro-S is by far the more versatile and, ...year 2015, Polaris totally re-imagined on- and off-trail performance and ...
2015 Polaris 800 Rush Pro-S Review + Video
Apr 15, 2014 - 2015 Polaris 800 Rush Pro S Review Video: The 2015 Polaris RushPro S is a ... the high end Pro-R version with a choice of a 600 or 800 engine. ... "X" Games, looked at the big picture of snowmobile performance. ... Interestingly, the Rush Pro-S tends to be much more versatile than its Pro-X counterpart.
2015 Snowmobiles of the Year: Best of the Flatlanders
Polaris snowmobile problems
Hi this is a common problem,
De7 usually is mistaken for DET. detonation.
either you are using low octane fuel or you need to get a new map setting. also depending on if you are running ethanol fuel or non ethanol fuel you can get a plug specifically for that and it can retard the timing slightly. that may help....
Snowmobile
Is this a carbarated engine? If so the carbs may need a cleaning. You probable have a plugged jet.
Top Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Winter Sport Expert? Answer questions, earn points and help others
