Hi there .. a 3com 2824 Baseline Switch I am dealing with shows nothing but 24 ethernet ports. The IP address shown is not accessible. not a console port either, nor a pin, nor a hole.. or should a designated eth-port behave as one ? getting bored with it Any clue !?
A very simple solution to r epairing all by yourself is getting help from handbooks, they're very detailed and complete in every way so for me it was my b est source to repair
one of the top sites for this is https://big-manuals.com/
SOURCE: how to reset settings of linksys srw2008p 8 port switch.
hmm.. router? try to check the router if it has an reset switch then press it with in 5-10 seconds...
SOURCE: I have a 3Com baseline 2816 switch that I can
To hard reset the switch back to the defaults
use a pen or sharp object and hold the reset button on back of the
switch in - then unplug/plug back in the power while the reset button
is still depressed until the power led goes to solid amber - The
switch is now in fail safe mode - Connect your pc/laptop to one of the
front panel ports and see if you can discover the switch - if you
still can't then configure your pc/laptop to the 169.254.0.0 - class
B network and run the discovery again
once you have discovered the switch and can login -hit the upgrade
firmware button and reload the code - you can check the progress at
the bottom of the screen which has a toolbar showing the status of the
upgrade
SOURCE: I have one 3COM 4200
Are you using any firewall. If so, try disabling it and try to communicate the switch once again. I am sure it might be an issue with the security software.
Thanks and regards,
Anil.B.R
SOURCE: 3Com Baseline Switch 2024 - Switch - 24 ports
Is it hsappening with all the 24 ports or with some ports ?
Might be an indiacation towards the duplex mismatch.
are you getting CRC errors on the interfaces ?
SOURCE: Ho to reset D-Link DES-1228P
This article teach you how to D-Link router to restore factory settings,di-524 as an example.
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release. (Note: Do not repower unit during this procedure.)
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
I hope this information will be helpful. Thank you for using FixYa!
