20 Most Recent 3Com Baseline Switch 2924-SFP Plus Questions & Answers
0answers
0answers
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.3) Once the switch has rebooted, enter a new password for the "admin" user account.4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
5/8/2013 3:24:00 AM • 3Com Baseline... • Answered on May 08, 2013
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE - Web Interface - Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection -Console Interface -Once the unit has successfully booted and the prompt presented -Enter "password" (without "") -Enter "admin" when the system prompts for User -Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands) -Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password) -Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE -Web Interface -Device > Configuration > Save Symptom: SW2900 Baseline Switch - Default console access disabled following password change From the web interface, the default user "admin" password is changed and console access is disabled Cause: When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
5/6/2013 4:41:31 AM • 3Com Baseline... • Answered on May 06, 2013
3answers
I have 3Com Baseline Switch
First,"There is usually a small button on routers that can be accessed with the tip of a pen or a paperclip. When you find that tiny button, hold your pen or paperclip down on it for approximately 10 seconds until the router resets itself to factory defaults."After that, you can contact the manufacturer to get some helps if you still have problem.BTW,I work for Ingellen Communication Equipment and we are a large fiber optic equipments manufacturer in Shenzhen.Kindly let me know your specific requirements so that i can help
8/30/2012 6:28:15 PM • 3Com Baseline... • Answered on Aug 30, 2012
0answers
0answers
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
7/19/2022 10:19:57 PM • 3Com Computers &... • Answered on Jul 19, 2022
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers 21473952-p02ntbe4zwfh4zdoomaey2km-2-0.png
2/1/2020 6:43:22 AM • 3Com Computers &... • Answered on Feb 01, 2020
How to factory reset a 3com Baseline 2824 switch
A very simple solution to r epairing all by yourself is getting help from handbooks, they're very detailed and complete in every way so for me it was my b est source to repair one of the top sites for this is https://big-manuals.com/
12/7/2018 4:35:17 PM • 3Com Computers &... • Answered on Dec 07, 2018
MY wireless mouse stopped working need help
Time for a new mouse! I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
2/8/2018 2:42:33 AM • 3Com Computers &... • Answered on Feb 08, 2018
HI, I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working. My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20. The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables. Good luck!
11/22/2017 1:56:04 AM • 3Com Computers &... • Answered on Nov 22, 2017
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
11/8/2017 8:27:10 PM • 3Com Computers &... • Answered on Nov 08, 2017
3Com Baseline Switch 2924-SFP Plus Logo
24 questions posted
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Baseline 3Com
  • Baseline 3Com
Most Popular Question
3com baseline switch
  • Computers & Internet
