Refrigerators Logo
S
Shemma Posted on Dec 05, 2018
How to replace dispenser actuator on Samsung RSG257AARS
Why not dispensing fabric softener
The signal to dispense comes from the timer board. I am not sure if you can use a multi meter on the dispensing actuators to see if you are getting a signal. My guess is you are getting a signal to all but the fabric softener actuator. If this is true you may have a bad board. I am sorry but I do not have the board testing ranges or procedure.
Samsung RSG257AARS, freezer is not cooling things. What can the problem be?
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
It might be that the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair an engineer will first cut the coolant pipe and drain the existing gas and then recharge, re-pressurise and seal.
I need to locate and replace a main board on a Samsung RS 67 LASH
Hi, Usual positions are either on the top or behing the panel at the rear of unit on RH side if your facing the back..
Samsung side by side fridge/freezer ice and water is not working after filter change
If your water and ice maker are not working, you may not have turned your water valve back on. If your water valve is turned on, try rotating your water filter further so that it completely locks as it may not be installed all the way. Once it is completely installed, press the "water" button for approximately three seconds until it turns blue. If this does not solve the problem, you may have a bad filter, here is a replacement filter that you can purchase to install into your refrigerator: http://www.freshwatersystems.com/p-3658-swift-green-sgf-dsb30-compatible-samsung-da29-00003b-refrigerator-filter.aspx
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
1helpful
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
No water out of the water spout
Does the dispense make any noise when you try to get water?
Internal water dispenser rf266ab rubber cover came off and it appears there is a piece missing that holds the plastic piece down to dispence water
Had same problem. Ordered a part that appears to just snap in and replace the broken water dispenser face at this website. http://www.repairclinic.com/PartDetail/Dispenser-Actuator/DA9704952B/2049390
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
