I can click-in and view details on everything else but not anything categorized as a vehicle. Is there some parameter I need to change?
SOURCE: 2000 Jaguar S-Type Battery
I had to change the battery in my 1999 S-Type, you will need the radio code, I also needed to reprogramme the board computer which is easy if you have your manual at hand, also the car might act strangely for a while, but this is explained in your users manual, nothing to worry about.
Hope this helps.
SOURCE: 96 ford explorer no power no crank no anything
Sounds like a connection problem/error. When you replaced the starter solenoid, do you remember how many wires you disconnected and reconnected?
Was there any indication ( sparks, etc) of accidentally causing a short when you replaced the solenoid?
Your initial problem of no start but hearing the click sound is almost a sure fire indication that the starter is NG. If the solenoid clicks, that means that it is applying 12 volts to the starter.
hope this helps Good luck Loringh
SOURCE: 2002 honda cr-v awd makes clicking noise when turning
Its been my experiance in the past, if its a front wheel drive, that one of the CV joints is going out, check the ones on the side of the car the noise is coming from.
SOURCE: need to change diesel pump as the vehicle is
you may not need to change the diesel pump but you definitely need to have some fuel calibration to avoid the black smoke. hope this helps
SOURCE: I have a 2003 envoy
I would check the igniton switch. GM had some problems with their ignition switches. I would check to see if power is getting to the starter solenoid when the key is turned to the starting postion. You should be able to get to the starter thru the passenger wheel well. I had a 2005 Trailbrazer have the same problem and it was the ignition switch, it's not to hard to replace.
