According to page 43 of the manual the option is under Setup Menu.
https://usa.yamaha.com/files/download/other_assets/0/319980/RX-V565_manual.pdf
SOURCE: I have a yamaha rx-v565,
It will not work. Your version of HDMI will not pass signal. That's the short version. The long version can be found by googling "HDMI forums" and you will find 1000's of others with the same issues. It's HDMI, not Yamaha or Sony or any other receiver manufacturer's fault. HDMI has been plagued by the recording industry to make sure "copyright's" are protected. And this has been the "nail in the forhead" of HDMI! The current version of it, which is 1.3b seems to be working "so far" And the fix for your receiver is not just software it's hardware as well. If your receiver is under warranty, Yamaha will update it for free. If it's out of warranty, Run HDMI directly from your source to your TV and digital coaxial or optical to your receiver. The fix is expensive. Hope this helps
SOURCE: My Yamaha receiver model rx-v565 audio is putting
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
SOURCE: We have a Yamaha RX -V565 and after listening to
chances are youve got a short at the rear of the receiver. look for frayed speaker wires touching the chassis of the stereo. use a flashlight. it only takes one tiny hair of a wire to short it out
SOURCE: my yamaha rx-v565 wont turn my sub woofer on.It
make sure the switch on your sub is on, and also if there are no "sub signals" then it wont kick on tru listening/watching somthing with alot more bass to see if it kicks on
SOURCE: How do I reset my Yamaha RX-V565 Home Theatre Receiver?
Unplug it for 10 min and plug it back in. If you need more specific help with an issue with this receiver, post a comment and I can help you further. Hope this helps.
