Https://www.myblackwebremote.com/
Code list 4
Lookup Code for your device
Device Category
- Select a category -
AUDIO
Blu-ray Player
CBL_SAT_DVR
Digital Converter Box
DVD
DVD/VCR Combo
GAME
HDMI Switch
HDTV Set Top Boxes
HOME AUTOMATION
HTIB(Home Theater in a Box)
Media Center PC
Sound Bar
Streaming Media Player
TV
TV/DVD Combo
TV/VCR Combo
TV/VCR/DVD Combo
VCR
Brand Name
- Select a brand -
- Select a brand -
Watch our helpful remote programming video or follow the instructions below for programming your remote.
Direct Code Programming Instructions
Using the code(s) provided above, program the remote control directly using the following steps.
Enter Setup Mode
Press and hold down the SETUP button on the remote until the red light on the remote turns on. Release the SETUPbutton. The red light will remain on.
NOTE: The red light with either be a small light at the top of the remote or the power on/off button.Press the device type button
Press and release the device button on the remote for the type of device you wish to control. The red light will blink once and remain on.
NOTE: If there is not a device button on the remote for your type of device, you can use any device button on the remote.
Enter the device code
Use the number buttons on the remote to enter the first code shown above. The red light will turn off after entering the fourth digit.
Tests the results
Point the remote at the device. Test the buttons on the remote to see if the device responds as you would expect. If the buttons do not operate the device, return to Step 1 above and use the next code in the list.
Repeat this process for your other devices
Testimonial: "i needed the codes i found how to already just need the codes"
SOURCE: need help programing my vizio tv to a blackweb universal remote
You don't program the TV to the remote, you program the remote to the TV
Find the Vizio codes on the paperwork that comes with the remote. There will probably be several codes. You need to try each one. Before programming turn the TV on manually. After put in each code try turning the TV off with the remote. Then try to turn back on and try volume up If OK everything else should work. Occasionally 2 different codes will turn off the TV in the test above. Use the one that allows the most functions to work
FINALLY not every "Blackweb" remote will control every TV You may need to get another one that specifically says it can control Vizio.
