SOURCE: How do you turn up the modulation in a Cobra 19
there are horse shoe presets inside the radio you need to turn each one till you get the modulation preset. i think that should do it. remember that you use somthing like a plastic screwdriver to turn the presets and not metal dont want a shock
SOURCE: how do i turn peak and tune my cobra 19 ultra 3
un-solder 1 leg of D11 diode, pull it out of the board, and make sure it does not short against anything.
That will bring your modulation up all the way. there are other adjustments that can be done, but without proper meters, you will most likely mess up the radio.
D11 will be a big step up any way.
SOURCE: how to modify a cobra 19 ultra iii cb
find DM1 and clip it. then you will have full modulation.
SOURCE: WHEN I TAKL HAVE DISTORTION
your not out of frequency. Your antenna is not tuned.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
