20 Most Recent Cobra 19 Ultra II CB Radio Questions & Answers
2answers
How to modify a cobra 19 ultra iii cb
i got a couple of them and i have them talking really good for what they are. if you go inside you can turn up the pods also you can take a small screwdriver and spread those coils inside near the back of cb!
12/7/2016 5:04:11 AM • Cobra 19 Ultra... • Answered on Dec 07, 2016
Modulation adjustment
its an inside job .
3/1/2015 7:45:00 PM • Cobra 19 Ultra... • Answered on Mar 01, 2015
Wiring a pa
right next to the external out put of the external speaker is a similer plug .It says PA. set the plug in the outlet and push on it to make sure it goes in and now you have PA.
12/22/2014 1:12:09 AM • Cobra 19 Ultra... • Answered on Dec 22, 2014
How to pick up cellphone conversatons on a cobra 19 ultra 111
you shouldn't be able to but if you do then take it to a tech and explain it to him and he should be able to fix it.
12/21/2014 11:36:11 PM • Cobra 19 Ultra... • Answered on Dec 21, 2014
Cobra 19 ultra iii
4 watts max
12/17/2014 8:51:33 PM • Cobra 19 Ultra... • Answered on Dec 17, 2014
Which pod controls wattage output on Cobra Ultra 19 3
L-21,L-22,and L-17 on a scope for 4 watts max output.
12/17/2014 8:43:11 PM • Cobra 19 Ultra... • Answered on Dec 17, 2014
Cobra ultra 111 modulation pot
you people keep asking 1/2 of a question so here's 1/2 an answer. google it , its there .
12/17/2014 8:13:04 PM • Cobra 19 Ultra... • Answered on Dec 17, 2014
How to boot up a cobra 19 ultra 3 cb radio
its easy, leave it as is and buy a small 100 - 150 watt kicker and you are good to go.
11/28/2014 2:05:00 PM • Cobra 19 Ultra... • Answered on Nov 28, 2014
How to adjust the mic gian on cobra 19 ultra iii
you can't
11/25/2014 9:38:00 PM • Cobra 19 Ultra... • Answered on Nov 25, 2014
Will the power band rfx75 rfdriver kit work on a cobra 19 plus
no it won't
11/25/2014 7:10:56 PM • Cobra 19 Ultra... • Answered on Nov 25, 2014
Cobra 18 wx st. peak and tune.
the only thing you can do is turn up the mod vari and thats it.
9/15/2014 4:03:29 PM • Cobra 19 Ultra... • Answered on Sep 15, 2014
How to adjust modulation on a cobra 19 ultra III cb radio
get a tech you can't do it.
8/23/2014 10:37:33 PM • Cobra 19 Ultra... • Answered on Aug 23, 2014
What can i do to make it talk louder
good coax better antenna and the radio.you will have to look online for that information on peaking that radio.
7/23/2014 6:51:07 PM • Cobra 19 Ultra... • Answered on Jul 23, 2014
Cant get cellphone frequancys
Under FCC law; cellular phone channels are blockedlocked out on most scanners. Tom
4/27/2014 3:22:24 AM • Cobra 19 Ultra... • Answered on Apr 27, 2014
Hello---- The Problem: Immediately after I power up the Ultra II, the channel indicater lights up, but only for about a half-second, then quickly dims out completely, and stays out. There is no static
It could be lots of things, display is failing, resistor network to display is bad, or cold solder joints, cable to display, driver to display going bad or caps bad, or maybe menu is set to low for display, need to see rig to decide.
3/26/2014 6:31:26 AM • Cobra 19 Ultra... • Answered on Mar 26, 2014
When you turn the vehicle on my cb lights up but
before I give you an answer is it just coming on and going off or is it staying on? you have the wx channel on that radio and when it receives power from any device to the radio the wx channel will come on and turn off immediately.Nothing wrong with the radio it is just a pain in the rear ,thats all.
10/28/2013 4:52:12 PM • Cobra 19 Ultra... • Answered on Oct 28, 2013
Cobra 19 ultra powers up but no audio or display on led
sounds to me you have to low voltage/ amps...try testing your power source with a meter the ultra is ideal @ 13.8 VOLTS
3/19/2013 6:14:40 AM • Cobra 19 Ultra... • Answered on Mar 19, 2013
I want to be louder and i need to know instrutions
turn VR2 all the way to the side that makes your modulation full.
9/14/2012 9:15:58 PM • Cobra 19 Ultra... • Answered on Sep 14, 2012
2answers
find DM1 and clip it. then you will have full modulation.
8/4/2012 6:02:56 PM • Cobra 19 Ultra... • Answered on Aug 04, 2012
I can hear on it but not many can hear me. they say it sounds as though im on the wrong channel
Have your SWR's checked. Free at most shops. it will make it should bad if they are high. although you may be able to hear. if they are high your RX will improve also..once its corrected. other problem could be its been bounced around/vibrations can cause the verticle boards to come loose on those models, and can effect either "IF" function, TX functions or RX functions... or all if they are all 3 loose.. if need more help just ask
4/17/2012 4:27:16 PM • Cobra 19 Ultra... • Answered on Apr 17, 2012
Radio Communications Logo
Popular Tags
53 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
problem immediately after power up
  • Radio Communications
