Pump should be connected or wired to its own circuit with no other outlets or equipment in the circuit line. Fuses and circuit breaker should be of ample capacity in the electrical circuit. THIS PUMP IS TO BE USED IN A CIRCUIT PROTECTED BY A GROUND CIRCUIT INTERRUPTER. If not properly wired it will throw the breaker. Here is a link to a troubleshooting guide. http://www.redlionproducts.com/media/31140/_the-red-lion-troubleshooting-guide.pdf
I too am having this problem. First I thought it was the amp, so I ditched the amp (was old anyways) and just directly hooked up to the speakers from the deck. It worked, then the problem came back. DualAV/Namsung customer service on these issues needs some help.
the two wires are hooked to the baseplate at the R terminal and the W terminal. there may be a switch somewhere on thermostat for electric or gas heat. make sure its in gas mode. make sure batteries are fresh and put in correctly in regards to polarity. make sure furnace is on when doing any settings with the thermostat. make sure themostat is set to "heat". make sure themostat is calling for heat (turn way up to be sure its doing that) . check the troubleshooting guide that came with the new thermostat.
Is it usb cam or what and what problem ur facing. Here are few laptop troubleshooting help to repair your laptop. In common just connect ur cam and system will detect new hardware and install driver it will start working. You may require to restart ur laptop. Hope this laptop troubleshooting guide helps u or explain in detail about ur problem.
