SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
SOURCE: zanussi zuf270x main oven not getting hot
I've just mended this myself and it took about 15 mins:-)
It's more than likely the heating element, you can get one off the internet for about £20 if you go for the electrolux replacement.
Open oven door and remove the trays, undo the four small screws on the back wall inside - not sure if you have to, but I turned the power off at this point. Better safe than not! Turn this around to the right wall as it won't come right out due to the bit of wire on the right (temp sensor maybe?).
If you've already got the new element you can guess what happens next; take out the 3 small screws holding in the element and gently pull towards you. It's attached to two wires poking out of two holes - take the bottom one off first as it seemed to have less tendency to fall back in the hole (I reckon that could be a real pain to get back).
Hold the wire still and wiggle the old element to remove as you will have less chance of damaging the wire that way. Reconnect the wires to the new element and pop it back together again.
Job done and after a year of waiting we now have double the oven space!
SOURCE: AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
SOURCE: Top oven (and Grill) have stopped working
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
