SOURCE: Wiring a Hampton Bay ceiling fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
SOURCE: I have three house wires supplied- white, red, and
make sure power is off before working on the fan wiring ..(trip circuit breaker)
here is what the house wires are
1. black is hot (power) all the time .. its normally connected to the black wire of the fans speed control switch .. that is normally operated by a pull chain ..
2. red is the same power as black except it comes from a wall switch .. this would be connected to the blue wire in the fan (that goes to its light) .. that will allow you to turn the light on an off from the wall switch ..
3. white is neutral .. it connects to both white wires inside the fan .. one goes to the fan the other goes to the light. .. if there is more than one light bulb then there will be more white wires .. hook them all together and to the white house wiring ..
4 then there is safety ground .. usually green or bare copper ... that is connnected to either a green wire inside the fan or bolted to the metal of the fan (often a green bolt is provided) .. the green wire is not required for the fan to run but is required as a safety to make sure no one gets shocked on the fans metal parts ..
after you wire the fan ..then turn on the wall switch .. if the light doesnt light then pull its pull chain until it does .. you can then tie up or remove that chain to prevent anyone from changing that position since you can now control the light from the wall switch you dont need that chain anymore .. the fan should come on slow med and high then off .. each time you pull its chain ..
SOURCE: I need a wiring diagram of the Hampton Bay fan
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
White (Neutral) White to White
Blue (Light to Hot) Blue to Black (optional)
Black (Fan to Hot) Black to Black
Green (Ground to Ground) Green to Green
If you do not have a green lead you might see a green screw to attach the ground wire from the house power. The fan has the optional light fixture future connect the blue wire to the black hot wire. If you have the optional light fixture you may want to connect it to a separate switch power.
