A
Anonymous Posted on Oct 13, 2018
Panasonic SA-XR25. On startup, there's loud crackling, popping audio for 10-15 min then it's ok. It's taking longer and longer to "warm up". It's plugged-in to a PS3 by optical cable. Fixable?
Shane
Level 1:
  • Contributor 4 Answers
  • Posted on Jul 12, 2022
Shane
Contributor
Level 1:
Answers
Questions
0
Helped
786
Points
I had the same issue and it turned out to be 4 bad 22 uF capacitors on the main board. I made a how to video here for anyone else with the same issue. https://youtu.be/INQLUGuHHFI
5 Related Answers
Anonymous
  • Posted on Jun 27, 2008
SOURCE: Panasonic Receiver SA-XR25
I thought it might be heat related, so I put a small battery operated fan behind the receiver, and voila, no more clicking. I just have to invest in rechargable batteries or an electric fan.
Anonymous
  • 32 Answers
  • Posted on Aug 26, 2009
SOURCE: Crackling seems to be coming from central speaker
in mu experience its a problem with voltage of your speaker.
did you tried before touching the speakers hard...
because the magnetic in the central of the speaker may damaged.
Anonymous
  • 12 Answers
  • Posted on Nov 27, 2009
SOURCE: audio crackling and popping noise for PS3
Might be a problem with your cables. Get new ones.
Anonymous
  • 1340 Answers
  • Posted on Nov 28, 2010
SOURCE: I just installed a Bose Cinemate II system. HDMI
No,you are not mistaken actually.I really don't have much to offer though.I just want to let you know that I have seen many problems with HDMI cables and no sound.HDMI does in fact transfer audio/video.Even though I do not like to use Wikipedia because anyone can edit the info,I check and see if it is accurate first and does give the best descriptions and is the quickest and easiest to find.This is a newer technology.Any new technology is usually not figured out until about year 5.In year 3,they are able to get the kinks worked out,but year 4 is already in production.They start designing and building the best version for year 5 next.Although 5 years isn't always achieved,it is more of a minimum to see the best possible of the technology.Happens with cars,TV's,VCR's,etc.Prices come down as everyone who wants it is greatly reduced by then also.Anyhow,here is a link to some info about HDMI.Scroll down to Communication channel protocols.Under TMDS there is some relevant info.You may not understand the terminology but basically it seems that there is an internal automatic muting with certain changes in the audio signal.It just sounds to me like the automatic mute is too sensitive right now and will improve over time.There is also some encryption taking place which is basically taking the output,scrambling it,sending it somewhere,and then being unscrambled and reproduced identically.Same as wireless internet.With all the various products being used,everyone has their own way of doing something.Since it isn't exactly made with exact specifications,there are many variations to interpret.If someone were to have ALL components made by 1 company,it would most likely work much better.How many people have that kind of setup though?Very few.There is not 1 company which makes everything they produce,better than everyone else's.Some make better radios,some TV's,etc.Right now,some of the better TV's are Samsung,LG,Vizio.Some better phones are AT&T,Panasonic.Bose has been at the top of the food chain for years for audio for that reason also.They do audio,nothing else,so they can put everything into it.I know this is a bit wordy but that's why I am here.To inform and educate people about things which they most likely don't understand and encourage them to spread the word.Hope you understand this anyhow.Basically,depending on how old your PS3 is,there may be compatibilty issues.With HDMI changing/upgrading rapidly,if your PS3 is an earlier version,it could simply be compatibility because PS3's even were changed as they sold more.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Here is the link for HDMI characteristics/operation.Good luck,Greg
http://en.wikipedia.org/wiki/HDMI
Testimonial: "Thank you for your response. I was able to get audio for my PS3 by connecting an optical cable from the PS3 to the Cinemate interface module."
Anonymous
  • 22 Answers
  • Posted on Feb 28, 2011
SOURCE: I have an RCA home theatre...model rt2910. I have
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
No power and no sound
check the fuse inside on the smps circuit .If its blown try replacing it if it dose not work take it to the service person .
Im having trouble setting up my SA XR25 reciever. I have 2 small bose speakers with a subwoofer. how do i connect the speakers to the reciever?.
Go to Bose.com, find the exact product in the roll down and it will lead you to manuals for the speakers.
Register and download the free manual for the SAXR25...
http://www.retrevo.com/support/Panasonic-SA-XR25-Receivers-manual/id/312dj786/t/2/
I don't have a remote for my panasonic sa-xr25. Can I turn off the surround/enhanced button from the receiver?
Get your reading glasses out. There's a button marked "Enhance Surround" two clicks to the left of the Volume Control.
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
1helpful
Looking for a new Panasonic SA-XR25 6.1 Channels
A quick search only revealed on online retailer that still had one in stock:
http://abcdealz.stores.yahoo.net/pansarx25.html
I strongly suggest calling them to verify that the unit is in stock prior to placing the order online.
Alternatively, set up a saved-search on ebay to alert you if one is posted, or post to "Want it now". (http://pages.ebay.com/wantitnow/index.html)
I suspect the unit is still under warranty. Call Panasonic to verify:
1-800-211-PANA
No darn pre-amp outputs on the XR25 model......arrrrg!
Different circuit boards are involved here, and what you propose would be cost-prohibitive in that you would have to come up with a 45 board, or rework the old board(very tedious!). Take the plunge and stay the course on factory built items in this case...accordianman
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
