SOURCE: OSD Lockout
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you
dismantle the casing, which voids any warranty.. so, if the monitor's
still covered by the warranty, or if money is not an issue, have it
repaired by professionals on an accredited brand shop (check your
warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on
the circuit board, and try to release it using something thin like a
screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop,
sending a continuous signal to the board (which keeps locking/unlocking
the OSD).
If so, your only solution (other than take it to a repair shop) is to
remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is
better than to have a message stuck on front of your screen all the
time..
This is a tried and working solution, since I had this problem myself
(with a Philips 190B monitor), and solved it successfully, with this
method.
SOURCE: Mattress Base
There is currently a voluntary recall on this very part. Visit www.storkcraft.com and click on recall. If your crib was manufactured between 2001 and 2008, fill out the form and you can get a free bracket replacement kit. You will need to look at the sticker on the base under the mattress (where the instructions are usually glued). Write down the model number, date of manufacture, etc. and fill out the form. I'm not certain whether the form submission will allow for a UK address, but I would think if it doesn't you could phone customer service and tell them you'd like the free bracket kit being offered because of the recall.
SOURCE: Frigidaire Front Load GLTF2940 full of pet hair
Why dont you shake out the maximm hair before loading into machine?
SOURCE: Using Skype, cat avatar shows. I want live feed from my web cam.
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
There is nothing more fun than traveling with your best
friend, especially if you travel alone.
Here are some helpful travel tips and suggested pet supplies
to have along in order to have a successful trip.
Pack your pets supplies
Make sure to take your pet belongings along with you, get
a doggie bag. It is important that your pet will have his familiar toys and
accessories, especially if you are going somewhere you and him have never been
before. Take the collar, harness, food bowl, pet bed and your pets favorite
toys. Make sure you take some snacks and treats for the road and make sure your
pet is familiar with the treats you give him, otherwise you can find yourself
in the middle of nowhere with a very upset pet.
You should also consider buying some seat covers or have
some nylons in the car in case youll have an unfortunate accident.
Another thing you might want to consider is getting a
booster for your pet, especially if you travel with dogs and cats. You must
make sure you travel safe. Any local pet supplies shop has these boosters.
If you have a naughty dog, make sure you take some calming
supplements with you in case it decides to go crazy just as you started
driving.
Another good tip before going to a long trip is practicing
beforehand. If your pet, especially dogs and cats, have never been into a car
or on a drive, it might be a good idea to have some short drives around the
neighborhood just to see if they are getting along.
In any event, planning ahead is always a good idea. It will make you feel confident that you have everything you need to have a safe and fun trip and make your pet calmer and easygoing so youll all have a blast!
You can buy one at most specialty pet stores or online at
one of these locations:
http://www.amazon.co.uk/tag/cat%20radiator%20bed/products
http://www.alphapetonline.co.uk/radiator-hammock-cat-bed/
http://www.ebay.ie/sch/sis.html?_nkw=New+Cat+Bed+Radiator+Hammock+Cats+kitten+Pet+beds
