Without the remote you can't, no way to enter unlock code. If you need a remote contact this comapny https://www.remotes.com/Default.asp?gclid=Cj0KCQjwxvbdBRC0ARIsAKmec9YVym_bjM2LDHPbWHL5z0Z9e_kpSZrLTcNWG7YysNOXq1_7N3gqRzwaAlr6EALw_wcB
SOURCE: locked my lcd bush
!st-Try this...... Unplug the unit for about 3-4 hours, it shoul go back to nornal_DEFAULT...
Hopethatworks.
SOURCE: Car Alarm
sounds like the drivers side key switch has failed remove the interior door panel and there will be a switch attached to the back of the key lock cylinder or around there it should be two or three wires also check the door jamb wire harness where the door closes for any broken or damaged wires, use a vot meter and see if you get power or ground to the opposite side of the switch when you use the key to lock and unlock the door if nothing changes and there is power or ground! at this switch i would replace it, i don't think there is one but if the car has a passenger side key hole try to unlock the car from that side and see if you get the same problem -jeff
SOURCE: i locked my tv through remote now i dont know how to unlock it
Please Help me unlock my TV. I cant use the remote
SOURCE: mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
