20 Most Recent Supersonic FC-2035 Television Questions & Answers
3answers
Code for universal remote
What type universal remote do you have? Try searching online for the manufactures site they should have information on the sequence to program as well as the various code for any given brand of TV. Often the model number is located in the battery compartment on universal remotes if it's not printed on the exterior.
5/12/2016 2:18:33 PM • Supersonic... • Answered on May 12, 2016
Supersonic SC-499 9-Inch Portable LED TV keeps shutting off. I tried a different plug, tried the button for charging. It turns itself off. How to recharge?
That usually occurs due to overheating or a faulty power supply board. Sometimes are easy as fixing a dry joint. It may also be that the internal Lithium battery has failed. They only have a certain number of charge / discharge cycles. A new one is $76 so not worth paying someone to repair versus a new one. https://www.google.com/search?q=Supersonic+sc-499+powers+off ..
3/27/2024 6:15:33 PM • Supersonic... • Answered on Mar 27, 2024
2answers
Looking code for my supersonic tv
If you have a universal remote control, you can set it up to be compatible with your Supersonic TV or JEBSON 3003ES device. Follow the instructions included with your universal remote to program it for use with your particular television or device
3/26/2024 10:33:47 PM • Supersonic... • Answered on Mar 26, 2024
How do I connect my Ellies Slimline 2 in 1 Universal Remote to my Supersonic Android smart television please?
Question edited for clarity, correct spelling of maker. Code for Supersonic
  • Sunstech 31331, 24244
  • Superior 22312
  • Supersonic 35456
  • Supra 32462, 34633, 33146, 44121, 43155
  • Supratech 25231
Instructions, but I don't like the idea that it is a .zip file. Scan it first. https://files.remotecentral.com/manuals/19-1/ellies/index.html ..
3/17/2024 6:29:37 PM • Supersonic... • Answered on Mar 17, 2024
Goldstone GS-32LCD codes not working on Supersonic
It depends what the Supersonic device is, but .... https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/30/2023 8:16:23 PM • Supersonic... • Answered on Dec 30, 2023
I need the codes so I can get my unit to boot up properly it is stuck in a boot loop and won't boot up
  1. Hard Reset or Factory Reset: Try performing a hard reset or factory reset on your device. This process typically involves holding down specific buttons for a certain period or accessing a reset option in the device settings. Be aware that a factory reset may erase your data, but it could help resolve the boot loop issue.
  2. Connect with Support: Reach out to Bushnell customer support directly. They may have specific instructions for troubleshooting a boot loop issue. Provide them with as much information as possible about the problem, including any error messages you may have encountered.
  3. Check for Firmware Updates: Ensure that your device's firmware is up to date. If there are any available updates, install them as they may include bug fixes that address boot-related issues.
  4. Battery Status: Ensure that the battery is charged and functioning properly. Sometimes boot loop issues can occur if the device is not receiving sufficient power.
  5. Professional Repair: If none of the above steps work, it's possible that there is a hardware issue. In such cases, you may need to consider professional repair services or contact Bushnell for further guidance.
12/26/2023 9:27:12 PM • Supersonic... • Answered on Dec 26, 2023
How do I eject the DVD from the SuperSonic SC-1312?
Ease the drawn out by prying gently with a blunt butter knife or look for the hole and use a paper clip in the hole and press. Then but a CD Lens cleaning Disc and run it a few times. The tracking Laser is as powerful as the Reading Laser and it can't read the track so throws an error. https://www.google.com/search?q=SuperSonic+SC-1312+stuck+DVD ..
12/17/2023 6:38:52 AM • Supersonic... • Answered on Dec 17, 2023
How to adjust the sound on a Supersonic SC-1512 TV.
12/13/2023 4:43:30 PM • Supersonic... • Answered on Dec 13, 2023
I have a SC1312 supersonic tv. The dvd will not spin nor stay in what can I do?
If the DVD on your SC1312 Supersonic TV is not spinning and does not stay in, there are a few troubleshooting steps you can try:
  1. Check the disc compatibility: Ensure that the DVD you are trying to play is compatible with the SC1312 Supersonic TV's built-in DVD player. Some DVDs may be incompatible due to different formats or region codes. Try playing different DVDs to see if the issue persists.
  2. Clean the DVD and the DVD player: Inspect the surface of the DVD for any smudges, fingerprints, or scratches. Clean the DVD gently using a soft, lint-free cloth, wiping from the center outward. Additionally, use a DVD lens cleaner to clean the DVD player's lens, as dust or debris on the lens can interfere with disc playback.
  3. Check for physical obstructions: Carefully inspect the DVD player's disc tray for any physical obstructions, such as foreign objects or debris. Remove any obstructions that may prevent the DVD from spinning or staying in the player.
  4. Reset the DVD player: Power off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and power it on. This reset can sometimes resolve temporary issues with the DVD player.
  5. Contact Supersonic customer support: If none of the above steps resolve the issue, it is advisable to contact Supersonic's customer support directly. Provide them with the specific details about the problem, including the model number (SC1312), and describe the symptoms you are experiencing. They will be able to provide further assistance, including potential troubleshooting steps or arranging for a repair if necessary.
6/28/2023 2:46:09 AM • Supersonic... • Answered on Jun 28, 2023
Supersonic television displays "no signal".
That's because there is no signal :>D Unless you are using an outdoor aerial on the roof and the signal via a aerial cable, your signal is not provided by 'Channel Scan'. In most homes, your television comes from a Cable Box or a Satellite box. The signal from those is fed to the television via an HDMI cable. On your remote, find the Source Button and scroll though the HDMI socket inputs.
Supersonic TV not working with HDMI (Reasons +FIX!)
https://techbullish.com > Smart TVs Dec 20, 2022 - What do you do when your Supersonic tv says no signal? · Switch off all devices connected to your tv · Unplug all connected HDMI cables · Switch ... Why is Supersonic TV not... · ‎How do I reset the HDMI port...
TV Says NO SIGNAL - What To Check - How To Fix
https://removeandreplace.com > Cable & Satellite Jan 14, 2016 - If it is just one TV that is showing the NO SIGNAL... -Be sure your TV is on the correct source or input as your CABLE or SAT BOX. -Press the TV ...
1/7/2023 9:05:18 PM • Supersonic... • Answered on Jan 07, 2023
Why won't my brand new supersonic sc-3314wnb turn on
if you followed all directions --possible defective return
11/16/2022 4:32:10 PM • Supersonic... • Answered on Nov 16, 2022
Supersonic SLM-3215 Television. How do I unlock my supersonic tv without remote. Television model slm-3215.
You can't. All televisions need a remote control for Advanced Functions. Just buy a new replacement remote. https://www.google.com/search?q=supersonic+slm-3215+replacement+remote ..
6/21/2022 2:03:38 PM • Supersonic... • Answered on Jun 21, 2022
The little supersonic TV I uses a 13in and I basically only use it for my camera monitoring. I don't know if my family press the wrong button on the remote control which is only used to turn the monitor off and on nothing more, but this morning when I went to turn the monitor on to view the cameras, it had a little box that said I had to run a channel auto scan. I'm not sure exactly what this means and how to start monitoring my cameras again on this scream.
Please read all of this before you do anything since my last suggestion may be the place to start. This means it "needs" to do this in order to find the OTA (over the air) TV channels which have recently changed. Go through the menu system & possibly Tools to find the auto channel scan and let it do that. I don't know why it would ask you to do this unless you also have the TV attached to the Internet, then it would know it needs this new channel scan, but I have four TVs in the house and none of them told me they needed a new scan. I knew this because I keep track of what is going on with OTA TV channels. So, let's assume you've done the scan again, you also say you don't know how to get it back to monitoring your camera. Once the channel scan is done it may be happy and simply find your camera again. If not, your camera probably came with instructions on how to set it up in the first place, find those and find how how to attach it to the TV again. If you've lost those instructions look up the make & model of the camera on the Internet to see if you can now download the pdf version of the user's manual and/or setup instructions. LAST: You may want to try this first: Most remotes have a button called "Input" or "Source" look for that button. With the TV on & pointing it towards the TV press the remote "Source" button, look at all the input sources it has & go through them one at a time and then wait for something or nothing to come up. One of these sources may be your camera.
8/11/2019 5:20:16 PM • Supersonic... • Answered on Aug 11, 2019
How do I remove key lock on my supersonic tv without remote. Tv model - slm 3217
not possible without remote...
5/29/2019 5:54:15 AM • Supersonic... • Answered on May 29, 2019
2answers
Is there a user manual for SuperSonic SC 280TV
You can look at this site and see if they have one. https://www.manualslib.com/
3/29/2019 8:39:57 AM • Supersonic... • Answered on Mar 29, 2019
Supersonic FC-2035 Television Logo
8 questions posted
Top Supersonic Televison & Video Experts
NOEL
NOEL
Ngoro
SmartAviator
SmartAviator
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Supersonic Televison & Video
Most Popular Question
code universal remote
  • Televison & Video
