SOURCE: Oven cuts out after ten minutes and comes back after cooling down.
The control switch on our AEG B3000, a similar oven, had burned contacts which prevented the fan from running in one selector position where the fan was to run when the heating element cycled off. The tech replaced thermostat which was not problem at all. If the fan does not run in this mode the heat stays at the top of the oven near the thermostat and prevents proper heat build up. Switching to 100% convection fan mode solved problem until switch replaced and all switch positions worked again. Hope technician will now refund for thermostat which was perfectly fine. Always check thermostat in boiling water before replacing.
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
SOURCE: AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
SOURCE: AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
