SOURCE: Serial number for nero 7
i downloaded the nero 8 trail version from the net but it needs a serial key to activate please send me the serial key for the activation and aslo tell me how can i crack it to make it full version
nero 7 serial key-->
1C82-A0K5-19E5-MAAX-400F-X1KK-M885
this should work out.Please do rate if this solves your problem.
SOURCE: how to save opera mini 4.2 in lg k20 and start the
My understanding is that the lg ks20 runs on windows mobile 6.
So you have two options, to download opera mini or opera mobile (which is much more powerful is more of a full web browser).
To download opera mini just go to mini.opera.com using your phone's web browser and it will instruct you on how to install.
To download opera mobile, go to http://www.opera.com/mobile/download/ and active sync your phone to install.
Hope this helps!
•You are running the IP feature set (S25C-12.0.1) in a Cisco 2500 series router
•You want to upgrade to IP PLUS (S25CP-12.0.1)
Use FL25-P= to order (see the price list for all available product numbers)
Example 2: A Complex Upgrade Order
More than one Feature License may be required in ordering an upgrade.
Ordering Example
•You want to upgrade from the IP feature set (S25C-12.0.1) running in a Cisco 2500
•You want to upgrade to the IP/IPX/AT/DEC PLUS (S25BP-12.0.1) feature set
You must use two Feature Licenses:
•One to upgrade from IP to IP/IPX/AT/DEC (FL25-C-B=)
•One to add the PLUS (FL25-P=)
For Upgrading Procedure Please check the below link.
The procedure is for all the Cisco Router
