SOURCE: Memory Full
hi
just had the same problem
solution : hold the answer and hangup buttons down for 5 seconds {press red and green and hold}
the parrot kit will then tell you it is erasing memory then it will say ready for pairing turn on your bluetooth on your phone doe a search find and select parrot enter default code 1234 when prompted as a pin and away you go
hope this helps bob
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
Any questions email: [email protected] Subject: omnitech bluetooth
SOURCE: Unable to pair Nokia N85 to Parrot car Kit
It's possible that you need to reset the parrot - seems it might only accept pairing with one phone. On mine you hold down the red and green keys together until she tells you that she is clearing the memory, then she prompts you to pair your phone
SOURCE: can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
SOURCE: I have a new phone nokia 6303 and tried pairing
you need to go to settings / paired devices / delete any old phones that are still stored as the parrot will only allow 5 paired devices. then try again. You may want to check your software and if your software is over 12 months old it will be a good idea to update your parrot, try parrot.com/support for more.
Dan
